Author Topic: Miniature Tools  (Read 272167 times)
0 Members and 9 Guests are viewing this topic.
Offline Art Rafael
Re: Miniature Tools
« Reply #480 on: August 15, 2014, 07:17:32 PM »
Thanks Oily.
It's been a week of errors and do-overs.
I decided to work on the frame and could find no acceptable preformed members anywhere.
Anybody know where small Brass (or for that matter - steel)  "I"  "H"  "T" or channel beams can be found.
Finding none, I had no choice but to try to fabricate something and settled on 1/4 inch "T" beams for strength and adaptability.
It looks crude, and it was darn difficult to create.
1/16 X 1/4 inch flat brass stock was angle cut, laid out flat in form and the joints silver soldered.
Then another flat brass stock was angle cut and laid out on edge to perfectly fit the previous member.
The two were mated, wired together tightly to hold the proper fit and shape and silver soldered along the entire length
to produce a strong structurally sound united frame piece.
Then bracing was fashioned and bolted in place with double 1-72 1/4 inch brass bolts.
Again, drilling perfectly spaced 1/16 inch holes (and so many of them) was challenging.
On my bench top can be seen other braces that will be strategically located and bolted on.
the rear axle and wheels were also installed
Ralph
« Last Edit: August 15, 2014, 07:27:30 PM by Art Rafael »
Re: Miniature Tools
« Reply #481 on: August 15, 2014, 08:02:08 PM »
Hi Ralph,  looks like you have been busy.  looking good, but before you go any further,
it looks like the angle frame lip are both facing the same way, 1 inside & 1 outside, or
am I seeing things ?
Frank
Re: Miniature Tools
« Reply #482 on: August 15, 2014, 08:22:45 PM »
Frank
T shape?
Re: Miniature Tools
« Reply #483 on: August 15, 2014, 08:25:59 PM »
I think brass shapes (angle and u-shapes can be found where they make strained glass.  i think I saw some on a rack with the lead came.
Re: Miniature Tools
« Reply #484 on: August 15, 2014, 08:29:43 PM »
Art, your sense of design and scale are amazing, looks like another great miniature coming along great.
Re: Miniature Tools
« Reply #485 on: August 15, 2014, 08:31:28 PM »
Also the model train folks used to have that stuff, there are still people who hand build brass locomotives..
Bigger shapes can be found in Muntz metal, small shapes are hard except for the model stuff, which you are gonnay pay dearly for..
Offline Art Rafael
Re: Miniature Tools
« Reply #486 on: August 15, 2014, 09:37:04 PM »
Hi, Frank.  Yes, I've been busy, and progress seems so slow - especially when every part has to be fabricated from scratch employing flat stock.
It just seems that everything I need does not exist, and it all has to be hand made.
But actually, there is where the fun is.  It's kinda like building your own erector set one piece at a time but with greater precision and with tighter tolerances.
Chilly is correct; the frame members are "T" shape, and a lip extends both inside and outside on each member.
I did find some of that stained glass angle and channel brass, but it is just too thin and flimsy for this "industrial" application.
Thanks Les.  It is coming together - slowly - since I'm designing it as it goes along with one part built to fit the previous and the subsequent part to fit the last, etc.
But I do have a picture in mind and some drawings  to work from, if not blue prints, on my desk pad to give a sense of scale.
And I am learning to appreciate the importance of sequencing; some operations must be done first to make subsequent operations less difficult or even possible.
Thanks, Rusty.  I have scavenged all the model and train sites and rummaged through all the hobby stores and metal places that I could find on the net and found none,
but I am fortunate to have found assortments of tiny bolts and nuts.
Offline Art Rafael
Re: Miniature Tools
« Reply #488 on: August 16, 2014, 09:18:24 AM »
Thanks Oily.  They (Oak Ridge) carry round brass stock and brass bolts & nuts, but their "I" "H" etc. beams are all plastic.
I'm still looking for a brass supplier to finish this project and for the next.
Ralph
Re: Miniature Tools
« Reply #489 on: August 16, 2014, 10:43:47 AM »
Art, Just in case you haven't seen these suppliers yet.
http://www.specialshapes.com/brassshapes.html
 http://www.hobbylinc.com/brass-hobby-and-craft-metal-tubing-sheets-strips-wire-rods
Don't forget to check out McMaster Carr they might have something too.
Re: Miniature Tools
« Reply #490 on: August 16, 2014, 01:07:33 PM »
Denver has to have some big model and hobby shops that carry scale building material, I would think.   There is a large chain, art supply store here that has the same, plus scale lumber for architects, unfortunately not in Colo.   Last time I was there I saw brass copper and aluminum tubing in squares, rounds and other shapes,  up to almost 1/2 in.  Grader looking good from here.
Re: Miniature Tools
« Reply #491 on: August 16, 2014, 01:34:59 PM »
hi Ralph,  I was glad to hear that I was wrong about the rails, you are the Master.
I am not sure if you are interested in material from the U.K. but here is another site to check,
they also list some of the suppliers, you might want to copy their names and google them.
www.wonderlandmodel.com/model-tools-and-materials
good luck, Frank
Re: Miniature Tools
« Reply #492 on: August 16, 2014, 04:27:21 PM »
http://www.specialshapes.com/Beams.html
Brass I-Beams  1/4" H x 1/8" W (and smaller)
Offline Art Rafael
Re: Miniature Tools
« Reply #493 on: August 16, 2014, 06:45:48 PM »
Thanks, guys.   With some such help I'll get this grader done, though it will be a while.  This project is testing me thoroughly.   Ralph
Offline Art Rafael
Re: Miniature Tools
« Reply #494 on: August 18, 2014, 02:17:15 PM »
The front truck is about done.   Ralph
