Author Topic: These things  (Read 2800 times)
These things
« on: May 10, 2013, 09:38:30 PM »
Found these in a bottom of a craftsman toolbox I got, most was just hammers an screwdrivers and a few wrenches. Mainly vintage an a few newer things. But what are these things?
Re: These things
« Reply #1 on: May 10, 2013, 09:46:58 PM »
Those go with Wile E. Coyete's ACME instant chemistry set, to hold flasks on the steel support stands.
Offline mvwcnews
Re: These things
« Reply #2 on: May 10, 2013, 10:34:30 PM »
More likely the size to hold test tubes;  last time I used one for its intended purpose was H.S. chemistry. (add sodium metal to water, capture the released hydrogen gas in a latex balloon, & hold a lit match to the balloon)  Modern safety concerns mean students no longer can manipulate sodium metal, or mix the right acids and bases to generate enough chlorine gas to bleach a cottonwood tree.
Offline amertrac
  • ny mountain man
Re: These things
« Reply #3 on: May 11, 2013, 05:30:35 AM »
I have seen similar brackets to hold pipe to metal  joists temporally while welding  bob w.
Offline harwill
Re: These things
« Reply #4 on: May 14, 2013, 01:31:12 PM »
Yep!  I'll third the motion - Those ar apparatus clamps to hold chemistry equipment via a ring stand or support frame.  Bella Lugosi used a lot of 'em! The thumbscrew end clamps to a vertical (usually) 3/8 steel rod; the opposite end holds the instrument of choice (test tube, flask, cylinder, etc.)
make good "third hands" for welding; wife uses 'em as plant stands...
"Sometimes I thinks Well..., and then again I don't know..."
Re: These things
« Reply #5 on: May 15, 2013, 02:12:47 PM »
 Or Dr Fraunkenschteins lab
 I was working in the lab, late last night,
when my eyes beheld an eerie sight
Re: These things
« Reply #6 on: May 15, 2013, 04:21:30 PM »
 I saw the hideous phantasm of a man stretched out,
and then,
on the working of some powerful engine,
show signs of life,
and stir with an uneasy, half vital motion...
Re: These things
« Reply #7 on: May 16, 2013, 11:46:21 PM »
Thanks for all the info. I don't get why these were in with tools, lol.
Re: These things
« Reply #8 on: May 17, 2013, 02:33:28 AM »
Because they had to be someplace and they weren't welcome in the pantihose drawer after the snagging incident.
