Author Topic: Parker Vise Wrench No.4  (Read 9939 times)
« on: October 05, 2012, 04:45:11 PM »
Well, I now have a Parker Vise Wrench #4, but no Parker Vise
Anyone know what vise this No. 4 goes with? Appears to be 1".
Marked-
THE CHARLES PARKER CO.
MERIDEN CONN. U.S.A.
VISE WRENCH NO.4
Re: Parker Vise Wrench No.4
« Reply #1 on: August 19, 2018, 07:45:09 PM »
6 years later, I have unearthed a C Parker vise , but it is not a swivel base model. It is too heavy for me to lift so I can investigate it further. The wrench got sold on Ebay quite some time ago, but I wouldn't have needed it anyway.
« Reply #2 on: August 19, 2018, 08:20:19 PM »
I need some Parker vise info. Is 88 1/2 a model # or the weight of the vise, or both ?
Offline wrenchguy
    • Wrenchguys videos
« Reply #3 on: August 19, 2018, 09:27:02 PM »
its model number, thats a nice 1, check here, scroll up or down however u call it to charley parkers.  thanks to the viseguys at garage journal.
https://docs.google.com/spreadsheets/d/1sHFRfY_DFXMz6bFeeYI7UKRpUd3aheAE86KBQRBGb9s/edit#gid=666157805
« Last Edit: August 19, 2018, 09:30:24 PM by wrenchguy »
« Reply #4 on: August 19, 2018, 09:44:16 PM »
I did a lot of searching at Garage Journal, but there are lots of  pages in the vise thread!
« Reply #5 on: August 20, 2018, 05:37:20 AM »
4 3/4 in wide jaws and weighs in at 94 pounds. I’ve found that the easiest way to deal with these larger vises is to unscrew the dynamic jaw and slide so that you’re dealing with two separate pieces. The "tower"(static jaw) will still be a little heavier, but much better than 94 lbs.
The downside is if everything is rusted together and you can’t get it apart, you then have to resort to plan B...get some young strong help.
Nice find! A couple hours with a wire wheel will have it looking like new.
Offline wrenchguy
    • Wrenchguys videos
« Reply #6 on: August 20, 2018, 07:09:00 AM »
I know theres alot vise madness there.  Thats why i put their work results link in my post.  did u click it? did it open?
Check all vise manufacturers specs to date.
Here it is again.  https://docs.google.com/spreadsheets/d/1sHFRfY_DFXMz6bFeeYI7UKRpUd3aheAE86KBQRBGb9s/edit#gid=666157805
« Last Edit: August 20, 2018, 07:15:30 AM by wrenchguy »
Offline wrenchguy
    • Wrenchguys videos
« Reply #7 on: August 20, 2018, 07:20:18 AM »
ur's is odd to the data sheets 88 1/2.  why?
« Reply #8 on: August 20, 2018, 09:23:32 AM »
Yes. The data sheet says 88 1/2 has a swivel base and pipe jaws. When I get it up off the ground, I will investigate further.
« Reply #9 on: August 20, 2018, 11:57:48 AM »
The pipe jaws part is correct, although they may have been removed, but that vise you have never had a swivel base. Unless I’m missing something.
« Reply #10 on: August 20, 2018, 12:07:22 PM »
Yes, I see some holes in the side that could be for mounting pipe jaws. I am sure  this one never had a swivel base.
« Reply #11 on: August 20, 2018, 12:19:25 PM »
Thanks to Mike, here is a photo from a catalog that shows the 88 1/2 with pipe jaws and a stationary base.
Offline wrenchguy
    • Wrenchguys videos
« Reply #12 on: August 20, 2018, 12:22:59 PM »
the data sheet is incorrect pertaining to the base.
« Reply #13 on: August 20, 2018, 12:25:14 PM »
It appears so, doesn't it ?
