Author Topic: Big and heavy  (Read 3580 times)
Big and heavy
« on: May 25, 2012, 07:47:27 PM »
Knowing this crowd this will go unguessed for about a minute and thirty seconds.   I just got it, was able to unload it without hurting myself.  Is missing one leg.  In the neighborhood of 200lbs.  Mole is one of the words cast into it.  I don't know why I bother, its just too easy in this bunch.  Must dig deeper.  OK, what is it, what did it do specifically, and if you're adventurous, when?
« Last Edit: May 25, 2012, 07:49:09 PM by john k »
Offline dimwittedmoose51
Re: Big and heavy
« Reply #1 on: May 26, 2012, 02:07:27 AM »
If Rube Goldberg was still around, I'll bet he could tell ya......lol
DM&FS
Champion Pawn/Flea Plunderer
Re: Big and heavy
« Reply #2 on: May 26, 2012, 07:37:56 AM »
Too many places to pinch my fingers. Clamps flat steel straps/banding maybe?
Offline kxxr
Re: Big and heavy
« Reply #3 on: May 26, 2012, 08:23:48 AM »
does it travel on a cable?
Re: Big and heavy
« Reply #4 on: May 26, 2012, 08:51:05 AM »
It took me a while to figure out it is sitting on 2 old tire rims....
I see a compound lever handle, and a blade, so , some kind of a shear? (banding tool is a good guess..) hmm
Awfull elaborate to be an ordinary bench shear ....
Re: Big and heavy
« Reply #5 on: May 26, 2012, 10:11:49 AM »
Does this help?  Technically, a band clamp, would be correct, but when the band/iron tire is heated, placed between the clamps, pressure is applied via a long bar, the tire can be made smaller, shrinking the diameter.  Which in its time was easier than cutting and rewelding the tire.  Now if I can find a roller.
Re: Big and heavy
« Reply #6 on: May 27, 2012, 06:15:13 AM »
Oh!  A tire shrinker!  Never seen one like these -- I'm used to more primitive tire shrinkers.  Cool!
Offline amertrac
  • ny mountain man
Re: Big and heavy
« Reply #7 on: May 27, 2012, 06:30:10 AM »
i could surely use that I have several good 16 inc tires and some 15 inc rims I wonder if shrinking them will distort the name on the tire   bob w.
Re: Big and heavy
« Reply #8 on: May 27, 2012, 12:01:26 PM »
Lettering should be fine, but you'll need tubes
