“You can use an eraser on the drafting table or a sledgehammer on the construction site.” - Frank Lloyd Wright
0 Members and 22 Guests are viewing this topic.
22 should make it a Dana axle, 5300 GVW, 4.10 gear ratio, NOT limited slip...This axle seems to have gone away sometime in the early 80's,That gear ratio and GVW combination seems to be unusual...
Thats the same rear-end that is in the truck I am borrowing the motor from for my fire-truck, have no use for the rear end, good rear, smoked alot of tire with it, never gave me a problem. Just drove truck to its final destination on Sat and towed home what was left of it including rear Sat eveningI know chances are you wont but if you did arrange pick-up it would be yours. Id like to see it go back to something it would have originally been found in.
Assuming it is a dana axle*, there is a long number stamped on the tube that describes all the parts and gears that went into the axle. looks like 603XX-X, 604XX-X or 605XX-X.
Seventeen axles?
