Author Topic: what type of drill bit do you use to drill Himalayan rock salt  (Read 8811 times)
Offline Sean
I have a chunk of Himalayan rock salt that I need to drill a hole for a piece of rope.  :angry:
What type of drill bit do you use to drill Himalayan rock salt
« Last Edit: July 06, 2016, 10:00:18 AM by Sean »
He who dies with the most tools wins!
Re: what type of drill bit do you use to drill Himalayan rock salt
« Reply #1 on: July 06, 2016, 09:33:32 AM »
Never seen Himalayan rock salt so I don't know for sure but I would think a hammer drill should do the job. If the rock salt is soft or brittle there is a chance this type of bit could shatter it. If you have a small piece try it on that first.
« Reply #2 on: July 06, 2016, 12:42:44 PM »
Try a small battery operated hammer drill they don't have a lot of hammer behind them and they are easier to control.
« Reply #3 on: July 06, 2016, 02:10:01 PM »
Just curious, what do you use it for?
Offline leg17
« Reply #4 on: July 06, 2016, 03:17:52 PM »
Melting ice off of Himalayan sidewalks?
« Reply #5 on: July 06, 2016, 04:54:34 PM »
Chilly can probably tell us what to drill with.
Those are for making Salt Lamps used for night lights, etc. There are some who say they emit negative ions or positive energy waves into the air.
« Reply #6 on: July 06, 2016, 05:17:16 PM »
Livestock salt licks.
They hang from the rope.
But why not get a mineral block?  They have salt plus many, many other minerals.
« Reply #7 on: July 06, 2016, 09:01:23 PM »
If leg 17 is correct I guess that's what the rope is for. You can walk down the side walk and drag it behind you.
Offline Sean
« Reply #8 on: July 08, 2016, 04:59:46 AM »
I used a 3/8" masonry drill bit in an ordinary drill.
Easy!  :cool:
« Reply #9 on: July 10, 2016, 09:24:22 PM »
But you don't need the sidewalk behind you free of ice; you need it clear in front of you.
« Reply #10 on: July 10, 2016, 09:33:47 PM »
Maybe walk backwards.
« Reply #11 on: July 10, 2016, 10:39:42 PM »
Nope.  You'd have to push it.  Or get your brother-in-law to do it.
« Reply #12 on: August 28, 2016, 02:36:05 PM »
You could use a diamond core bit. Dry, as water will melt the rest of it. It is such a soft mineral you could use any steel drill bit on it. I think a regular twist drill bit would do a good job.
A hammer drill would crush it to bits.
It is just NaCl, sodium chloride, or salt. The mineral halite is a crystalized form.
