Author Topic: Inside a ratchet: How they work  (Read 496462 times)
0 Members and 28 Guests are viewing this topic.
Offline d42jeep
« Reply #315 on: November 13, 2018, 02:09:10 PM »
Here are all the pictures I have left of that set and ratchet. The sockets were a mix of Ward Master and Truth but looked very similar except for the markings.
-Don
Offline lauver
  • Belton, TX
« Reply #316 on: December 03, 2018, 08:22:15 PM »
Gang,
I recently acquired a nice little Fleet 1260-1, 3/8-drive round head ratchet that may be of interest to some of you.  It has a 45-tooth ring gear and a single see-saw pawl in the ratchet core.  This ratchet was made and sold between ~ mid-1950's and mid-1960's.
Here's a few photo's:
Assembled complete,
Ratchet core and components disassembled,
Ratchet core & body disassembled,
Let me know if you have any questions or comments.
« Last Edit: December 11, 2018, 01:34:10 PM by lauver »
Offline d42jeep
« Reply #317 on: December 10, 2018, 07:24:10 AM »
I had picked up a S-K 1/2” drive ratchet with a broken drive side at an estate sale a couple of weeks ago. My tool collecting buddy Jason told me that if I emailed S-K customer service and gave them the part number they would send a free repair kit and that is exactly what happened. Here are a few before and after pictures.
-Don
« Reply #318 on: March 04, 2019, 09:46:25 AM »
Have had this ratchet awhile but didn't take it apart for pics till last weekend.
A JET 3/8" fine tooth. Comfy handle for a polished hourglass-style, 60 teeth, sliding pawl. Think FACOM, S-K TUFF 1, or the newer Asian Craftsman tri-wing round head.
Selector switch is a knurled ring on the back. Not the easiest to flip, but on the other hand it wouldn't be easy to accidentally reverse it. Actually like this ratchet as it has a very small gear head. Might find a use in tight restricted areas.
« Reply #319 on: March 04, 2019, 09:50:04 AM »
-Don
Your middle picture shows the difference of construction with the drive gears perfectly, Don.   :smiley:
The older one is totally disassembleable - the new one is not. About the only advantage is if someone is selling the vintage tool and you find the newer style drive gear in it you can tell right off.
« Reply #320 on: March 04, 2019, 05:41:13 PM »
these are Craftsman 1/2,3/8 and 1/4-drive ratchets with a "V"-shaped shifter, stamped with the "Craftsman" double-line logo on the raised panel, with "Forged in U.S.A." and a "V" code on the reverse panel.
1/2" overall length is 10.3 inches, and the finish is chrome plating.
3/8" overall length is 6.8 inches, and the finish is chrome plating.
1/4" overall length is 5.2 inches, and the finish is chrome plating.
The ratchet head is fitted with an oil hole closed by a steel ball
Although not marked with a patent notice, the design of the V-shaped shifter is described by patent #D185,651, issued to R.M. Vose in 1959 with assignment to Moore Drop Forging.
At least the PO didn't store the big boy rat in a water bucket, but he certainly did not KEEP RATCHET WELL OILED.
thank you for watching
« Reply #321 on: March 05, 2019, 06:02:31 PM »
Nice triple play!  :grin:
« Reply #322 on: March 05, 2019, 06:22:43 PM »
Wow!!! Nice tools, and great job of cleaning them up!! Regards, Lou
Kobalt "gearless" ratchet
« Reply #323 on: April 30, 2019, 06:40:12 PM »
First new ratchet in awhile. A Kobalt "gearless" racthet in 3/8". Typical Taiwanese-handle, very big round head - even bigger than the Bonney (which I thought was massive!)
Still trying to figure how this thing functions. Apparently when torque is applied in the desired direction the hex shape of the center drive pushed the 6 roller bearing out, producing an interference fit which "jams" the mechanism for movement. Releasing the torque allows the rollers to retract back into the inner ring, allowing for freewheel. How the direction changing knob switches the inner mechanism remains a mystery. Very smooth, seems like it would take high forces easily. Plus it's quick release!
About the only down side is the placement of the two retainer flat coil springs. they are not interchangeable. Apparently the mechanism requires a certain amount of free-play to operate, and the flat springs appear to be different thicknesses. Switching them messes up the fine play adjustment. As does too much light grease.  :shocked:
So if you need a ratchet with minimal arc swing (and the big head isn't an issue) I'd say this tool would work.
« Reply #324 on: April 30, 2019, 07:46:19 PM »
Bog did it 90 years ago--with only four roller bearings.  Those clever Americans!
« Reply #325 on: May 04, 2019, 06:07:40 PM »
Gang,
Assembled complete,
Just found a TruTest 1/4" with the fork selector/roll pin pawl. Not the smoothest mechanism out there but usable.
Offline Flotsam
« Reply #326 on: August 01, 2019, 08:54:39 PM »
Gang,
Assembled complete,
This is very interesting.   I recently acquired a Tru-Test T1060-1.   the  1/4 in equivalent made by  Proto Challenger.   I have managed to take the ratchet apart by removing the retaining ring.
 So my ratchet  is missing  the spring and does not work.  No i know i didn't lose it.   There was no spring action within the ratchet prior to taking it apart.     So I am trying to find a spring of the correct size  and also find out where that spring goes?     Any help you can provide would be appreciated.     I really would like to fix it by finding a spring rather than the whole ratchet capsule.
thanks in advance.
« Last Edit: August 01, 2019, 09:20:31 PM by Flotsam »
« Reply #327 on: August 01, 2019, 09:11:25 PM »
Try springs from Bic lighters, or ball point pens.
Offline Flotsam
« Reply #328 on: August 01, 2019, 09:31:51 PM »
Thanks I will try a spring from there.  My question is where does the spring go?
From looking at it, it is not apparent where the spring would sit
« Reply #329 on: August 04, 2019, 04:27:34 PM »
If I recall correctly, it's a "floating" spring. It's not really held in but where it's at it can't really go anywhere, and lends it's spring tension to keeping things where you set it - by tension only. If need be I can take my little Tru-Test apart and try to get better pics.
