Author Topic: help a non-carpenter name his tool  (Read 7320 times)
« on: January 23, 2014, 05:26:47 PM »
This is a tenon bit?
close but no,  it's a .....
JAN 176 by skipskip, on Flickr
JAN 175 by skipskip, on Flickr
Re: help a non-carpenter name his tool
« Reply #1 on: January 23, 2014, 05:29:31 PM »
Round iron thingy.
« Reply #2 on: January 23, 2014, 05:33:22 PM »
Round iron thingy.
I see you are a wrench collector also
« Reply #3 on: January 23, 2014, 05:50:19 PM »
Oh, heck yes.
But, sometimes, I learn odd things hanging out here.
I don't quite know why or how, but it happens....
« Reply #4 on: January 23, 2014, 06:21:28 PM »
If it is not a round tenon cutter, it must be for cleaning up the bottom of the hole cut for a round tenon. (Papaw is not a woodworker, either.)
« Reply #5 on: January 23, 2014, 06:21:50 PM »
Are you sure it's not a tenon cutter? It looks like one to me!
For a ratcheting brace, but still a tenon cutter...
Can we see the working end?
« Reply #6 on: January 23, 2014, 07:13:32 PM »
Tenon cutter, or hollow auger, think chair spindle ends.  It is hollow right?
« Reply #7 on: January 23, 2014, 07:25:04 PM »
It is hollow ,but the blades are on the face
tenon cutter works like a pencil sharpener?
JAN 169 by skipskip, on Flickr
« Reply #8 on: January 23, 2014, 07:29:00 PM »
pretty good sized one would not be surprised if it wasn't a wheelwright's spoke tenon maker.
Offline Jim C.
« Reply #9 on: January 23, 2014, 07:30:50 PM »
It looks like a round tenon cutter to me.
« Reply #10 on: January 23, 2014, 08:06:51 PM »
The tool called a "pointer" which is used before using this one, works like a pencil sharpener.   Many tenon cutters only have one blade, and several are adjustable as to size and depth.   A pointer is shaped somewhat like a funnel.
« Reply #11 on: January 23, 2014, 11:59:20 PM »
Yup this is a single size tenon cutter. There are a lot of multi sized cutters and adjustable cutters. This one cuts a single size and does it very very well.
 For when you have a lot of same sized tenons to cut
Offline Mike H
« Reply #12 on: January 24, 2014, 05:31:31 AM »
I believe what you have there is a dowel cutter/maker
« Reply #13 on: January 24, 2014, 06:58:20 AM »
Tenon cutter or hollow auger is what it's called.  Like Scott says, this one is the sort that comes in different sizes.  The blade (or blades, depending on the maker) cut away the parts that don't look like a tenon and set the shoulder.
« Reply #14 on: January 24, 2014, 11:32:49 AM »
Since things are going so well here, I am adding pics of the rest of the woodcutters box.
from left to right
the tenon cutter w have discussed
an adjustable tenon cutter?
a smaller cutter, but works differently?
and a pointer?
JAN 177 by skipskip, on Flickr
