Author Topic: help a non-carpenter name his tool  (Read 7310 times)
Re: help a non-carpenter name his tool
« Reply #15 on: January 24, 2014, 11:51:56 AM »
The two solid cutters are tenon cutters for sure. The adjustable one? I just don't know. Looks more like a chuck to hold and spin something, but then I can't see it too clearly.
 The pointer is a tool I need. I am having to rough out with a drawknife freehand
  Here are the two other common styles of tenon cutter, and what they do.
  Both need new blades. I am working on it.
 I need some tool steel 1" wide and about 1/8+" thick and at least 4" long,
 if you see any scraps laying around............(he begged)
 Oh I just grabbed a stick of firewood off the ground, for testing. :)
« Reply #16 on: January 24, 2014, 03:04:57 PM »
>an adjustable tenon cutter?
Looks more like for cutting threads...?
« Reply #17 on: January 24, 2014, 07:53:48 PM »
took me a minute to understand this
threads, like pipe? nope not sturdy enough
wood..? OH!!!
like broomhandle threads...
or legs into the bottom of a table  threads
« Reply #18 on: January 24, 2014, 08:03:08 PM »
See...you should have bought all those broken chisels at the yard sale ;P
Yes...threaded dowls were very popular for a while, one of the glueless type of  joints
I Don't know that I have seen one with multiple blades tho....
« Reply #19 on: January 24, 2014, 11:23:00 PM »
The pointer is a neat tool, is actually in the fun realm to use.   Scott, for your new blade steel, use an old lawn mower blade, the price is right.
« Reply #20 on: January 25, 2014, 04:06:03 AM »
I have a thread cutter for wood, much more modern though.
It only has one v-shaped blade to cut the thread.
It cuts threads for push brooms, oaint sticks, etc.
« Reply #21 on: January 25, 2014, 06:33:12 AM »
Yep, #4 is a pointer.  It's kinda hard to make out #2, but it doesn't look like any adjustable I've ever seen.  Those look like one or the other of the two Scott posted.
« Reply #22 on: January 30, 2014, 06:31:07 PM »
Also once referred to as hollow augers..which they sort of are...an insideout drill bit...
1873 catalog...lots of sizes....
