Author Topic: need advice on big shear purchase  (Read 6224 times)
« on: July 24, 2013, 10:34:59 AM »
BIG shear for sale at local auction.
should I buy it? what to look for?
can I move it with ordinary equipment?
http://www.collarcityauctionsonline.com/servlet/List.do?auctionId=40&startLotId=669&lotId=669&page=info#
Re: need advice on big shear purchase
« Reply #1 on: July 24, 2013, 10:59:04 AM »
Depends if you are buying it to use it or resell it.  Is it single or 3 phase? It looks like it probably works. Try to move the top blade looking for badly worn pins. Look for major chunks out of the blade. Dull can usually be sharpened. Start it if you can. Listen for nasty motor and drive noises. I can't tell what it has for a clutch.  Check that it works. Has the frame been cracked and welded? If it is open gears, are they worn out or missing teeth? If it is a closed gearbox, how bad does it leak? Was it used in a steel fab shop or a scrap yard. If it was in a scrap yard, it is probably pretty tired all over. See if you can find a tag that gives the rated thickness that it will cut. Usually with those, if it fits in the jaws, it will cut it.
« Reply #2 on: July 24, 2013, 06:20:34 PM »
The Dayton Foundry & Machine Co went away in 1915 guy....
« Reply #3 on: July 24, 2013, 06:35:39 PM »
that might explain why they haven't answered my emails
« Reply #4 on: July 24, 2013, 06:40:41 PM »
resell
single phase late model motor
I'll look more closely, thanks
open gears, but in a OSHA style cage, hard to get too personal
in its life prolly all of the above, it's last owner was a building contractor
I'll look, any ideas where to start?
I bet.
any idea the weight, will a regular flatbed tow truck do it?
Thanks for the help.
« Reply #5 on: July 25, 2013, 08:08:50 AM »
If Rusty is correct, this old shear is about 100 years old.  I'm betting that it will last another hundred. I went through some of the auction items. Will everything go that cheap?
« Reply #6 on: July 25, 2013, 12:47:15 PM »
Prolly not.
It's an odd auction format.
On Line for a week
one day, mid week, you can go see the stuff.
bidding will end next Sunday,
I seldom get great deals on these, last time I got one item ( huge electric welder, weighed 500 pounds, didn't work, $25)
« Reply #7 on: July 31, 2013, 11:43:50 AM »
Did ya get the shear or anything else?
« Reply #8 on: July 31, 2013, 12:02:46 PM »
Shear went for $4000, too much for me.
I did get a "valve grinder set"
 it wasn't exactly what I was thinking, but pretty cool nonetheless
JUL 244 by skipskip, on Flickr
and an old sign
JUL 259 by skipskip, on Flickr
