Author Topic: torch/light  (Read 3874 times)
Offline amertrac
  • ny mountain man
torch/light
« on: June 26, 2013, 07:55:48 AM »
I believe this is a torch that fits a miners helmet. or something close . there must be another part to it
 this is all I got  .FIVE ($5.00)  plus shipping of six dollars and 10 cents ( $6.10 ) It may be worth less or more I have no ides .paypal 4% ( THEY HAVE TO GET THIERS)  OR GOOD CHECKS
Re: torch/light
« Reply #1 on: June 26, 2013, 09:25:14 AM »
It's an old alcohol torch. Only thing missing is the snuffer/cap. Good buy for someone!
Offline amertrac
  • ny mountain man
Re: torch/light
« Reply #2 on: June 26, 2013, 12:43:56 PM »
there is a  threaded cap on the top of the tank  bob w.
Offline amertrac
  • ny mountain man
Re: torch/light
« Reply #3 on: June 26, 2013, 12:54:48 PM »
cap
Offline Batz
Re: torch/light
« Reply #4 on: June 26, 2013, 05:06:27 PM »
I believe that is a Carleton Co. "Spartan" alcohol torch. If so the air tube will be rectangular, Brach Mfg. Corp also marketed an identical torch under name "Soderall"
Patent was awarded 1921.
There would have been a rubber tube that fitted the metal air tube, the torch is lit and the operator blows gently in the rubber tube, this gives a intense flame at the tip. These torches were popular with jewelers.
I own a Spartan but I would be interested if it were something different.
There should be some makers marks on the front of this torch.
Batz
« Last Edit: June 26, 2013, 05:40:23 PM by Batz »
Offline amertrac
  • ny mountain man
Re: torch/light
« Reply #5 on: June 26, 2013, 06:05:04 PM »
MR. BATZ, The square copper/brass rod that runs up the side is solid t kinda thought that being heated by the flame expanded the alcophol in the tank making gas to feed the light
under some green I found victor alcohol  torch  patented I bet this would clean up nice. too bad the shipping was so costly  bob w.
on second look the tube is a tube when you clean the green off the ends    MY BAD
Maybe I should try to clean and investigate farther. I am finding a lot of stuff that was put away years ago   bob w
« Last Edit: June 26, 2013, 06:10:48 PM by amertrac »
Offline Batz
Re: torch/light
« Reply #6 on: June 26, 2013, 06:10:48 PM »
Could you have a look at what size/cost flat rate box it would fit in for me? Or perhaps it would be cheaper to pack it yourself.
The US postal website will give you an idea to shipping costs to Australia.
The rod should be a tube, the hole is small.
Cheers
Batz
Offline amertrac
  • ny mountain man
Re: torch/light
« Reply #7 on: June 26, 2013, 06:16:43 PM »
Offline amertrac
  • ny mountain man
Re: torch/light
« Reply #8 on: June 26, 2013, 06:18:20 PM »
pm me with your snail mail address and telephone no I would need it for customs
Offline Batz
Re: torch/light
« Reply #9 on: June 26, 2013, 06:31:51 PM »
Sent
