Author Topic: old saw or not ??  (Read 4247 times)
Offline leach
old saw or not ??
« on: June 09, 2013, 04:37:10 PM »
a find i had in a scrap pile i had dug through.
it has a circle with the letter n in it .
and it is heavy 5 to 7 lbs
ok i tried it out on a 12 inch tree trunk wow if it was a dock saw they worked there behinds  off
ok new photo on teeth thanks for all the info you all are great glad to be part of the bunch
        LEACH
« Last Edit: June 11, 2013, 07:53:04 PM by leach »
Re: old saw or not ??
« Reply #1 on: June 09, 2013, 06:50:13 PM »
Heavy, iron handle, off hand I'd say it was an ice saw, for harvesting ice from ponds.  The symbol?
Offline leach
« Reply #2 on: June 09, 2013, 08:46:58 PM »
yes i think your are right i did find it by a old copper mine that had ice houses where they stored big blocks of ice back in the day 1940-1950
                 thank you for the info
                                                    LEACH
« Reply #3 on: June 09, 2013, 09:17:37 PM »
I would be interested to see the logo you mentioned. I was told years ago that ice saws had far fewer teeth per inch than wood saws, usually 2 or 3 TPI  (if I recall correctly).   Thinking about that metal handle and how fast your gloves would freeze to it makes me think this is more than likely a wood saw. As far as age goes I would think your in the ball park with your estimate. How thick is the blade on your saw? I know that the ice saw I have is way thicker than any hand saws I have.
Offline leach
« Reply #4 on: June 09, 2013, 09:39:46 PM »
yes it very thick 3 teeth per inch 3/16 thick i will post it better tomorrow night ok
Offline leach
« Reply #5 on: June 09, 2013, 10:28:17 PM »
so sorry about that it is 1/8 inch thick i put my mic to it but to the eye i looked thicker .
Offline dowdstools
« Reply #6 on: June 10, 2013, 02:18:45 AM »
Actually, I believe what you have there is called a docking saw. It was used to quickly cut timbers to length. An ice saw is very similar, but has larger teeth with deeper gullets between the teeth.
Lynn
« Reply #7 on: June 10, 2013, 10:55:17 AM »
Lynn
I'm with Lynn.  This is a docking saw.  It looks to be shorter than mine, but the handle is identical.
