Author Topic: A very Strange and Unusual Saw  (Read 5321 times)
« on: May 06, 2013, 12:38:27 PM »
This is a rather unique and unusual saw, and it also has some unusual claims.  I wish I could tell you that I've put it to the test, but I haven't, and probably won't.  This example appears to be unused and I don't want to change that.  The teeth are very sharp as is the tip.  The blade has a very shallow hollow grind, probably to make it easier to drive and withdraw.  I don't know what kind of steel this would have been made from but it must have been extremely tough.
What follows is from an advertisement that appears to have been put out by the manufacturer, one Lewis E. Williams of West Groton, Mass.
Shepley's Patent
Double-Edged
Drive Saw
for
Plumbers and Carpenters' Use, or for any occasion
where Holes are to be Bored
__________________
No. 1 cut shows the Saw and Handle in a straight condition,
While no. 2 shows the position for use.  By shifting a slide on the
handle puts it into position for driving, as seen in cut No. 2.  After
having driven through your board or plank, take a claw hammer and
withdraw it.  The hole having been made you can proceed to saw any
way you may desire.
This saw is peculiarly adapted for Plumbers and Carpenters' use
and can be used where a common brace and bit cannot.  It is made of
the best steel and can be driven through a two-inch board, either way
of the grain, if necessary, without breaking.
This unusual saw was patented by Granville T. Shepley on Feb. 19, 1889; pat. no. 398,350
Datamp link below.
http://www.datamp.org/patents/displayPatent.php?number=398350&typeCode=0
« Last Edit: May 06, 2013, 12:40:39 PM by mikeswrenches »
Re: A very Strange and Unusual Saw
« Reply #1 on: May 06, 2013, 03:05:33 PM »
Never seen anything like it and it does look dangerous to use.
« Reply #2 on: May 06, 2013, 03:38:50 PM »
I hesitated to post this, but to me this thing looks like it would make a better weapon than a saw.  It definitely falls in the "very nasty" category.
« Reply #3 on: May 06, 2013, 06:41:25 PM »
That is a mean looking tool. Does the blade fold all the way into the handle? Uncle Lewis, he was a clever old guy.......
« Reply #4 on: May 06, 2013, 06:44:03 PM »
Never seen one of those before.
But, I sure wouldn't mess with anyone waving one around....
I wonder how many are stuck in beams with snapped off blades?
« Reply #5 on: May 06, 2013, 07:05:42 PM »
The blade does indeed fold into the handle.  Plus there is a brass 'keeper' that slides down one side of the handle that locks the blade in place.  If you carried it in your pocket there is a good chance that the "family jewels" would remain intact.
You can just make out a portion of the brass on the handle in one of the pictures.
« Reply #6 on: May 07, 2013, 04:05:35 PM »
Probably invented by a Klingon.  Looks like it.
« Reply #7 on: May 07, 2013, 07:56:29 PM »
It looks like the "trekkies" are alive and well and have now invaded Tool Talk :).  Make this thing 5 or 6 times bigger and I would think any Klingon would be proud to own it.
« Reply #8 on: May 08, 2013, 08:45:44 AM »
No need to make it bigger -- it's a Klingon sgian dubh.  You know, the small knives carried in the stocking tops of highlanders.
« Reply #9 on: May 08, 2013, 01:28:06 PM »
"No need to make it bigger -- it's a Klingon sgian dubh.  You know, the small knives carried in the stocking tops of highlanders."
I'm afraid I'm not as well versed on Klingon weaponry as I should be.
