Author Topic: Civil War period doe.  (Read 4890 times)
« on: April 08, 2013, 08:55:48 AM »
The list of tools for the mountain howitzer calls for "One wrench, (for nuts Nos. 1 and 4,)"  Its weight is given as one pound.  There is no accompanying drawing of this wrench.  One use of this wrench would be setting up the folding frame for the fire place of the forge (it collapses to fit into a chest carried on a pack saddle).  The nuts visible on the one photograph I have of an original are hex nuts, and the nuts shown in the drawings are also shown as hex nuts.
I have no idea what the thing might look like.  I *think* the numbers refer to the size of the nuts, as the various nuts are not numbered in the drawings available to me.  Two of the nuts have limited clearance, so the wrench must be on the thin side.  The material -- steel or iron -- is not specified.
At the very least, I would like to find images of wrenches from around 1850 so I know what they should look like.
Anybody have any suggestions?  Information?
I'm going to start this week to try to cold forge the fire place pan.  We haven't found anyone who will build it per the drawings, and we got a $400 bid to make it up with straight sides like a cake pan -- which won't work at all.
Re: Civil War period doe.
« Reply #1 on: April 08, 2013, 10:33:16 AM »
Well, I found one answer.  The numbers refer to the size of nuts.  The No.1 is for square nuts 3/4 inch flat to flat, and the No.4 is for square nuts 1 1/2 inch flat to flat.
I still need to see what such a wrench looked like circa 1850.
« Reply #2 on: April 08, 2013, 11:18:47 AM »
« Reply #3 on: April 08, 2013, 12:44:25 PM »
Thanks, John.  I've saved off the photo.  I found a pair of wrenches this morning from about the same date, and they look similar to this one.  The thing is, all of these are blacksmith made.  The one I'm looking for was most likely factory made -- over 600,000 were made just for the mountain howitzer kit.  It was most likely issued elsewhere, too.  But the issue ought to resemble the smithed wrenches to some degree.
Offline anglesmith
« Reply #4 on: April 08, 2013, 06:44:36 PM »
Branson, I doubt that there was much difference between a factory made "smithed" wrench and the one made by the little smithy on the corner, except the factory smith would have had access to some form of power hammer and other tooling to make his work easier and faster, but basicly it was still by hand and eye! My impression is that drop forging with open dies didn't evolve till much latter? The only production forging machines that were in use during the civil war were Henry Burden's Horse Shoe making machines (51 million shoes a year!) and his rivet and dog spike making machines. Although one would never know, Henry may have had a "wrench" making machine in a corner of the Troy Iron Works! Here are a couple of links.  http://www.farmcollector.com/equipment/henry-burden-horseshoe-making-machine.aspx
http://en.wikipedia.org/wiki/Henry_Burden
Graeme
Clalification
« Last Edit: April 08, 2013, 08:20:08 PM by anglesmith »
« Reply #5 on: April 08, 2013, 10:18:40 PM »
Hmm I have a few of those, let me see what the widths are.
Burden Iron Works?
right up the road from here... maybe I should  take a look
Offline Bus
    • The Wrenchingnews
« Reply #6 on: April 08, 2013, 10:59:02 PM »
Could they of been cast rather than forged?
« Reply #7 on: April 09, 2013, 08:37:50 AM »
Graeme
Clalification
Wow!  Graeme, this is amazing information!   I knew nothing about the manufacture of these shoes or the machines that made them other than the fact that the Union supplied ready made shoes in three sizes.   Artificers in the field were issued all the tools for making shoes by hand if the need arose as well, but the ready made shoes were issued in 100 pound lots.  Just amazing.  Thank you!
« Reply #8 on: April 09, 2013, 08:56:20 AM »
At the moment, I have no information here.  I was wondering whether they might have been cast.  On the other hand, trip hammers of massive size are illustrated in Diderot's two volume Pictorial Encyclopedia of Trades and Industry from the mid-1700s.  I've found the marks of trip or power hammer work on heavy military iron work.
« Reply #9 on: April 09, 2013, 09:16:09 AM »
More on Burden and his factory here:
The Industrial Archeology of Henry Burden & Sons Ironworks in ...
northbennington.org/_assets/​Burden/​rolando.pdf
He even mined his own iron ore!
Offline anglesmith
« Reply #10 on: April 09, 2013, 07:25:50 PM »
 Branson, Henry Burden is very interesting, the fact that a immigrant Scotsman helped change the course of the American Civil War is fascinating to me! ( I have long been intrigued by how much invention/technology the world owes to the Scott's)  I was able download this book yesterday Written (compiled) by his daughter in 1904 it seems to contain much more information including drawings than I have been able to find before. I have only just browsed it so far.  http://archive.org/details/henryburden00prou  I don't know about you but my computer skills/knowledge leaves a lot to be desired,the one I downloaded off the left hand list was the PDF 6.6M. it worked ok!
I did d/l that Archeology article also.
Graeme
« Reply #11 on: April 10, 2013, 08:20:59 AM »
Graeme,  great find, that book.   The patent drawings are wonderful to say the least.  I've just browsed it myself and found so much useful information!  Thanks!
Offline anglesmith
« Reply #12 on: April 10, 2013, 08:53:03 PM »
Branson, a little more research into Henry B has brought this book up. http://books.google.com.au/books?id=W6jGh80u0iYC&pg=PA139&lpg=PA139&dq=henry+burden+horseshoe+machine&source=bl&ots=j1fqLrrN-6&sig=MC6fS345KgIxZSnhBC4A0nr9nxQ&hl=en&sa=X&ei=lhFmUc8i6peJB5fhgJgM&ved=0CEcQ6AEwAzgU#v=onepage&q=henry%20burden%20horseshoe%20machine&f=false
It has a chapter on the use of horses and mules during the civil war, it is still in print. It may have more information to help your overall research into the mountain howitzer company's.
Graeme
« Last Edit: April 10, 2013, 08:58:56 PM by anglesmith »
« Reply #13 on: April 11, 2013, 08:25:01 AM »
Wonderful stuff, Graeme.  Another thank you for your help.
« Reply #14 on: April 12, 2013, 10:57:24 AM »
I may have found it.  At least I have a photo of a contemporary DOE wrench dug up at an artillery site from the Battle of Resaca -- May of 1864.  Note the angle of the open ends to the shaft of the wrench.
Anybody seen one like this before?
