Author Topic: Duro 4500 ignition set  (Read 4048 times)
Offline Fins/413
« on: February 17, 2013, 10:33:53 AM »
Thought I'd double post this since some of you guys aren't on Garage Gazette.  Just got this its mostly here. Its a 19 piece Duro 4500 set. It was $12.90 in the 39M catalog. Its missing the E64, E66 and E68 ignition wrenches a 3" durolite screwdriver(4S3), 4" spinner handle(4573) a Spin Flex adapter(4570). Can anyone identify the splined socket looking thing, it has 1/4" female drive on one end and the other is a round hole that looks like 9/32" dia. Its possible this is a different set then the 4500 since only the even wrenches are missing, they are the same as the odd sizes but with ends reversed.
1959 Chrysler New Yorker
1982 E150 Ford van
Re: Duro 4500 ignition set
« Reply #1 on: February 17, 2013, 11:32:52 AM »
Those screwdrivers probably broke when dropped!
Sweet set!
Offline Fins/413
« Reply #2 on: February 17, 2013, 11:43:28 AM »
Do they get brittle?
1982 E150 Ford van
« Reply #3 on: February 17, 2013, 12:17:48 PM »
I believe Durolite starts fairly brittle & gets worse over time...
Can anyone confirm this?
« Reply #4 on: February 17, 2013, 01:26:29 PM »
If it was solvent softened cellulose, which was comon, yes, it will turn into something resembling cracked glass ....
No idea what the spline tool fits, but I have an ignition wrench set that also has a stamped wrench with a spline cutout in it, so there is something out there, somewhere, with a spline screw on it....
(Probably to keep joe homeowner from letting the springs escape from his magneto...;P)
Offline lauver
  • Belton, TX
« Reply #5 on: February 22, 2013, 09:59:20 AM »
Fins,
I don't have any Duro catalogs, but I'm wondering if this is really an ignition set.  It looks to me like this is a typical 1/4 drive set that somebody has added some ignition wrenches to.
The only Duro catalog (1935) I have seen used 45nn model numbers for their 1/4 drive sets and 17nn model numbers for their Ignition sets.  Also the ignition sets were sold in tool rolls and did not include sockets or drive tools.
Not trying to start a range war, just asking...
Offline Fins/413
« Reply #6 on: February 22, 2013, 03:50:54 PM »
The info came out of the 39M catalog. It suprised me too as I figured like you it was a 1/4" set that someone added wrenches and pliers to. It may still be that but there is a 4500 ignition set in the 39M catalog
1982 E150 Ford van
Offline lauver
  • Belton, TX
« Reply #7 on: February 22, 2013, 10:03:54 PM »
Fins,
Sounds reasonable, but I had to ask.
« Last Edit: February 22, 2013, 10:10:17 PM by lauver »
