Author Topic: No numbers, no name, no nuthin' ??? What is it?  (Read 3269 times)
Offline KTHOMPSONJR
« on: November 06, 2012, 01:33:50 PM »
Daycare manager found this on one of the closets after a remodel. No one has a clue...
Re: No numbers, no name, no nuthin' ??? What is it?
« Reply #1 on: November 06, 2012, 01:54:17 PM »
I don't know, but I'd be very, very nervous if someone approached me holding that.
Offline Mac53
« Reply #2 on: November 06, 2012, 03:39:28 PM »
What does the end of that cable look like? Can you get a photo if it facing the other way?
-Marcus-
« Reply #3 on: November 06, 2012, 04:29:00 PM »
Something Darth Vader used.It will be interesting to know the answer.I think a photo of the end of the plug will give the clue.
Offline Fins/413
« Reply #4 on: November 06, 2012, 04:32:03 PM »
Looks like some kind of high voltage probe.
1959 Chrysler New Yorker
1982 E150 Ford van
Offline mrchuck
  • retired Federal LEO Ranger
« Reply #5 on: November 06, 2012, 04:42:54 PM »
The connector is a PL-259.
Looks like an "arc" will be produced between the electrode probes.
Shock therapy device most likely.
Molon Labe
Offline superzstuff
« Reply #6 on: November 06, 2012, 04:52:46 PM »
Looks something like a moisture meter probe to check moisture content of lumber.
« Reply #7 on: November 06, 2012, 09:52:21 PM »
Daycare operators use them on both severely congested and runny nose kids.
Depending on which condition, you either hook it to AC or DCEP on a small welder and stuff half of the probe up each side of the kid's nose.  Step on the footpedal a time or two and the rugrat is cured.
« Reply #8 on: November 07, 2012, 03:18:24 AM »
home made Cattle Prod?
Offline Ietech
  • "OLD GUYS RULE"
« Reply #9 on: November 07, 2012, 01:17:43 PM »
After looking at the connector I would guess that is for testing coax cable used for connecting TVs an such tp the roof antenna  or cable box -- to test the cable for proper installation of the end connectors. (Just a guess) Basically it's a continuity tester.
« Last Edit: November 07, 2012, 01:38:25 PM by Ietech »
