Author Topic: Tools  (Read 3354 times)
Offline oddman
Tools
« on: October 01, 2012, 08:47:43 PM »
DONT KNOW WHAT IT IS OR WHAT IT DOES
Re: Tools
« Reply #1 on: October 01, 2012, 08:50:59 PM »
I don't know either, but I'd sure like to see it in action.  Welcome to ToolTalk.
Re: Tools
« Reply #2 on: October 01, 2012, 08:59:55 PM »
Welcome to Tool Talk!
Strange device!
Any markings, more pictures from different angles?
Re: Tools
« Reply #3 on: October 01, 2012, 09:38:44 PM »
This looks sorta like a saw set, for  circular saw.   First lift the arm with the hammer, rock back the lever, then when the lever with wooden handle is pulled down it lifts and drops the arm with the hammer, spring pressure pulling it down with some force.   A saw blade could be mounted and rotated on the spindle to the right?    The wing nut on the front allows the rod to slide to the right, allowing any size of circular saw to go under the hammer.   This is a good one, ruggedly made for what purpose?
« Last Edit: October 01, 2012, 09:54:46 PM by john k »
Re: Tools
« Reply #4 on: October 01, 2012, 10:02:43 PM »
I agree with JohnK, by using the trip handle, the spring force keeps the set the same from tooth to tooth. The flipper on the end is probably ground to two different angles for different types of saws. Does the center post where you mount the blade move closer and further from the anvil when you loosen the clamps on the shiny rods? Like for larger blades.
Offline geneg
Re: Tools
« Reply #5 on: October 02, 2012, 05:31:03 AM »
I also agree.  Look up Belsaw or Foley-Belsaw,  They have a multitude of saw blade equipment.
Offline oddman
Re: Tools
« Reply #6 on: October 03, 2012, 10:01:13 AM »
 YES THE PIECE THAT SUPPORTS THE CONE ITEM IS ADJUSTABLE IN AND OUT ON RODS AND THE CONE IS ALSO ADJUSTABLE LEFT TO RIGHT BY LOOSENING THE WING NUT    I WILL TRY TO ADD MORE PICS      THANKS FOR WELCOMING ME TO THE FORUM
Offline oddman
Re: Tools
« Reply #7 on: October 03, 2012, 01:42:30 PM »
ANOTHER PICTURE
Re: Tools
« Reply #8 on: October 03, 2012, 03:48:50 PM »
Priceless conversation piece.
Offline oddman
Re: Tools
« Reply #9 on: October 10, 2012, 03:46:28 PM »
I HAVE FOUND OUT WHAT IT IS.           JOHN K  AND JOHNSIRONSANCTUARY   WERE  RIGHT  .      IT IS AN APPARATUS FOR SETTING SAW TEETH.         PATENT AUG 13, 1901     #680484     BY JOSEPH GOTTSMAN, NEWARK NJ        THERE IS NO MANUFACTURING MARKS OR NUMBERS         I ALSO FOUND AND PRINTED THE PATENT AND DRAWINGS  AND DISCRIPTION FROM FROM USPO.         THANKS FOR THE HELP GUYS.
