Author Topic: No clue what this is  (Read 2804 times)
Wikus
  • Guest
« on: September 21, 2012, 01:08:30 AM »
Hi peeps. I found this in my late father's garage, I have absolutely no clue what it is, I figured maybe for cutting holes in wood? or am I mistaken? Any help and naming of it would be much appreciated :)
Thanks!
Re: No clue what this is
« Reply #1 on: September 21, 2012, 07:09:24 AM »
It's an adjustable hole saw. Usually has two cutters.
Offline superzstuff
« Reply #2 on: September 21, 2012, 08:02:07 AM »
We used these in the toolroom to cut holes in thin material, sheet metal and gasket material. With one cutter it has to be used in a mill or drill press. We called it a trepanning tool.
« Reply #3 on: September 21, 2012, 09:11:40 AM »
Trepanning tool?  You were doing brain surgery in shop?
Offline superzstuff
« Reply #4 on: September 21, 2012, 09:47:12 AM »
No, but when asked if it was hard work, we always said, "It's not brain surgery". hahaha (sorry)
Offline anglesmith
« Reply #5 on: September 22, 2012, 06:02:08 AM »
 I call it a Trepannig tool also. I have trepaned 6" holes in 3/8inch plate  with such a tool. Heavy duty drill press, very slow speed with plenty of cutting oil and it is amazing what can be done.
Graeme
Offline thiggy
« Reply #6 on: September 22, 2012, 08:39:57 AM »
The term that I learned for this type of hole cutter is a fly cutter
« Reply #7 on: September 22, 2012, 12:12:16 PM »
Tank cutter - used to cut holes in galvanised iron water tanks - superceded by hole saws and plastic water tanks.... Used with a brace - too vicious and dengerous in an electic drill
« Reply #8 on: September 22, 2012, 01:19:26 PM »
Clamp down the work to the drill press stoutly, and do not get your hands within the same time zone!!
 I use these often. I will never love them
Offline Wikus
« Reply #9 on: September 22, 2012, 03:06:17 PM »
thanks so much everyone. sure clears up my find :)
