Author Topic: Antique Turning Tool Thingy  (Read 3755 times)
Offline Los Altos Trading
« on: September 15, 2012, 04:16:52 PM »
Hi All -
I opened up a consignment shop earlier this year and have been getting a few things I have been unable to identify. This is the first old tool I haven't been able to narrow down and hoping someone here can help out or have some ideas.
The  tool itself is about 13 inches long and is mounted on a heavy wood base. It appears that you place your hand on the right side guard and turn the wheel with your thumb. This moves the gear system which turns the long metal bar that runs the length of the top. Under the lower cross beam there is a thin serrated saw-like cutting edge. The piece about 1/4 from the right that has a movable part that seems to contact with the cutting edge and would likely cut whatever was between. It looks like there should be a round piece that fits through the movable part that might is held into place by a small screw mounted at a 45 degree angle on the movable part.
There is a label on the bottom most of the letters are not visible or have been worn away. From what I can make out it could possibly say:
????? Pain(t)er
??? (C)utter
Any ideas? Thanks in advance for looking.
Re: Antique Turning Tool Thingy
« Reply #1 on: September 15, 2012, 06:07:40 PM »
Sort of reminds me of a wall paper cutter I saw in a store?
« Reply #2 on: September 15, 2012, 06:14:43 PM »
Some sort of dowel maker, maybe?
Offline Mel Larsen
« Reply #3 on: September 15, 2012, 07:17:25 PM »
Looks like there might be some letters or numbers on the top of the base and the larger wheel.  What are those?  Could you maybe post some photos from different angles?
Mel
« Reply #4 on: September 15, 2012, 10:08:20 PM »
kinda leaning toward it being a pleating machine.....
hmm
seeing the 'cutter' might help....
« Reply #5 on: September 15, 2012, 10:41:57 PM »
I did some looking for pleating and crinolating jigs, but struck out.
Offline RWalters
« Reply #6 on: September 16, 2012, 07:47:10 PM »
Window shade cutter?
Offline Provincial
« Reply #7 on: September 16, 2012, 08:05:19 PM »
Similar, but it appears that the cutter travel is too short.
Offline Mel Larsen
« Reply #8 on: September 16, 2012, 08:30:18 PM »
I'm thinking that the bottom word in the label is "trimmer"
Mel
