Author Topic: Need Post Hole Digger Info  (Read 9881 times)
Offline Mailbox Man
« on: September 11, 2012, 02:21:15 PM »
Hi Folks, I'm new here and hope I'm going about things correctly!
Hopefully I correctly attached some photos of a post hole digger my wife found at a reuse center here in Michigan. I have a small business installing mailboxes and this has become my most prized tool. In the right soil nothing is faster! Two or three turns and I can pull out a 6 inch plug of soil. It really has been a time and work saver.
There are no manufacturing markings that I can find. I really would like to find another to have as a back up in case I ever break this one. I have done a lot of searching on the web but never found another one like it.
Does anyone know the name of this type of post hole digger or anything about who made it? Any info would really be appreciated.
Thanks!
« Last Edit: September 11, 2012, 02:25:29 PM by Mailbox Man »
Re: Need Post Hole Digger Info
« Reply #2 on: September 11, 2012, 03:19:04 PM »
I had one , my son "Inherited" it when he borrowed it and hasn't returned it.It works about twice as good as a two handle type. I would suggest you watch the farm auction  sales , or check out some rural flea markets.
Looks like that's where the ebay ones are coming from.
Might try Craigs list also.Estate sales is another place , your wife would love to go for you!
Offline Mel Larsen
« Reply #3 on: September 11, 2012, 05:19:39 PM »
I have a couple of diggers very similar to yours, One is 4 inches in diameter and the other is 6 inches.  They came with 5 extensions for the handle, each 4 foot long.  I was told that they were used to clean out or dig shallow wells.   My neighbor said that his 20 foot well for his garden was dug with such a tool.
Mel
« Reply #4 on: September 11, 2012, 05:21:18 PM »
I dont see how that would dig very well, I also am attracted to a nice post hole digger but I am un-clear as to how well that one might work
« Reply #5 on: September 11, 2012, 05:33:31 PM »
It's not the type you just push down into the hole, it's sorta a cross between that and a screw augar, you turn it, and the 'lips' act like a threaded augar and chew off some dirt (note the opposing angle to the 2 lips), then you squeeze and lift it out. They work very well in fact, except where you have big rocks, then nothing works...
(OK, a 5 ton excavator works, but it leaves rather large post holes..)
« Reply #6 on: September 11, 2012, 06:01:41 PM »
Works just like an old nose augur.  Same principle but with two cutting lips.
Offline Neals
  • Alberta, Canada
« Reply #7 on: September 11, 2012, 06:15:48 PM »
Around here the most common type looks much like yours except the tips are exrended and joined together and brought to a bit of  point. In my experience they cut better and don't allow as much loose dirt to fall back in the hole. The downside is it can be a real pain to get wet clay out of them. Most farm auctions have one at reasonable prices. Usually $5.00 +/-
« Reply #8 on: September 11, 2012, 06:20:04 PM »
First one I've ever seen I believe. Was gonna ask too, how the heck it works with the edges bent in.
Won't get very far jamming that into the ground.
MailboxMan
  • Guest
« Reply #9 on: September 11, 2012, 07:26:04 PM »
First of all, thanks to all of you for taking the time to reply!
I am still brand new to this forum so please bear with me. Can someone please tell me why I can no longer see the 3 photos I posted with my original post? I saw them right after I first posted and I see that some of you are referencing them. Can you say learning curve? ;-)
Now some feedback to your feedback.
To KeyKepper- I have seen those types on eBay and as you say, they are similar. However they are very different. I also have one of the types you posted and I know where you can buy them new. But they are like night and day. The ones you linked to are curved at the bottom and join together in the middle. My post hole digger is open in the middle/bottom. Thanks for looking them up!
To Mel Larson- Are the diggers you mention open in the center like mine? Mine is adjustable. If you look closely at the second photo you can see that if the shiny new bolt I put in is loosened you can move the metal grooved wedges that stick out the top to widen or narrow the width of the cutting blades (also called ears or lips).
To 1930- The inward facing “ears” or cutting blades are angled to screw into the soil. With nice moist dirt they screw down the sides of the “plug” of soil. When the top of the assembly compresses on the top of the plug, it just keeps the whole thing together. I just pull it straight up and I have a big 6-8 inch plug of soil. I tap it out and do it again. With dry, rocky soil it still can break it up, dig down deep and then I use a traditional two handle, clamshell digger to pull out the loose soil. The round bottom, joined in the middle styles that KeyKeeper was nice enough to post still don’t do as nice of a job.
To Branson- I’m curious about your use of the term “nose auger”. Is that what KeyKeeper posted the links to? Also, are you from Branson, MO? I graduated from Hollister in 1974!
To everyone else, thanks for your comments and observations!
Offline Mel Larsen
« Reply #10 on: September 11, 2012, 07:26:48 PM »
You don't jam them into the ground,,,,,you twist them into the ground, something like a auger.  Thus the reason for the long "T" handle.
Mel
« Reply #11 on: September 11, 2012, 07:56:47 PM »
You posted as a guest, rather than a member. That will limit what you see on Tool Talk.
« Last Edit: September 11, 2012, 07:58:49 PM by Papaw »
Offline Mailbox Man
« Reply #12 on: September 11, 2012, 08:04:36 PM »
Doh! Thanks Papaw. I now see what I did wrong now on my second post.
And thank you for hosting this Forum!
« Reply #13 on: September 11, 2012, 08:10:57 PM »
You are welcome! And welcome to Tool Talk!
Offline thiggy
« Reply #14 on: September 11, 2012, 09:14:31 PM »
I have a couple of these augers at my farm in Miss.  One seems to be identical to the first one posted on Ebay.  The other has a release which allows one side of the auger to open to facilitate dumping soil.
