Author Topic: Only Two Whatitzs this time around....one is a Craftsman  (Read 4959 times)
Offline dimwittedmoose51
« on: September 03, 2012, 07:57:34 PM »
The Craftsman item looks like some sort of jig apparatus for a lathe, but the only number on it is a 9012.
The other item is some sort of valve maybe for a transmission on a tractor or semi tractor.  Was just hoping to get it narrowed down a bit closer.
Thanks in advance.
DM&FS
« Last Edit: September 03, 2012, 08:01:21 PM by dimwittedmoose51 »
Champion Pawn/Flea Plunderer
Offline Provincial
Re: Only Two Whatitzs this time around....one is a Craftsman
« Reply #1 on: September 03, 2012, 10:30:21 PM »
#1 looks like a fixture to sharpen saw blades, perhaps a chain saw.  It may be missing some parts.
#2 is a High/Low range shift valve for a Fuller (Eaton) Roadranger transmission.  It is an air valve and runs a slave cylinder that moves the shift fork for the range shift collar.  It was clamped to the side of the gear shift lever just below the shift knob.  Newer versions are built into the shift knob.
« Reply #2 on: September 04, 2012, 02:22:16 AM »
Hmmmmmmm, I'd love to see a YouTube video with #1 in action!!    and thanks for clarifying the shifter piece....
thanks Provincial....
DM&FS
Offline geneg
« Reply #3 on: September 04, 2012, 05:32:11 AM »
Number 1 is a sharpening jig for chisels & plane blades.  It is mounted on a bench grinder and the slide allows you to go across the wheel at a consistent angle.  There were several discussions of it on the previous edition of ToolTalk.  I do have an instruction booklet for it but no videos.  I'll dig it out & scan it.  Gene
« Reply #4 on: September 04, 2012, 05:07:14 PM »
Yup, it looks like the fairly large one too.  I am sure it was marketed for sharpening joiner blades as well. If it will do a 6" wide blade it surely was.
 The bracket screws to the bench in front of the grinder (at least many of them did).
« Reply #5 on: September 04, 2012, 06:51:07 PM »
Guys:  I'm thinking 6" wide or maybe even a little wider. setting the grinding angle on an expensive blade would give me the willies.... .  If aluminum parts have their won "patina", then this piece looks a lot like the finish on the very first drill I bougt from Sear in maybe 1968.  Funny that part number doesn't come up in Google searches.  Sears computers really don't like that number....lol
Thanks for the help.....
DM&FS
Offline bobby1
« Reply #6 on: September 10, 2012, 08:34:13 PM »
i got one the grinder jigs in some stuff at a auction this year i thought i would hang on to it and see if i could mount it a grinder that was all i could come up with
Offline geneg
« Reply #7 on: September 12, 2012, 06:23:00 AM »
Hello,  Found the boxed one I have.  I got it in S. Florida & the instructions had been partially consumed by something.  Let me know if I need to email you a higher quality scan.  Gene
Offline clovis
« Reply #8 on: September 18, 2012, 06:06:13 AM »
Wow...pretty cool. I've been messing with tools for years, but I don't think I've ever seen one of those.
Offline Ietech
  • "OLD GUYS RULE"
« Reply #9 on: September 18, 2012, 12:58:50 PM »
Thanks in advance.
DM&FS
Here is some info on your 2nd item
http://www.google.com/patents?id=zIpVAAAAEBAJ&pg=PA1&source=gbs_selected_pages&cad=2#v=onepage&q&f=false
« Last Edit: September 18, 2012, 01:12:06 PM by Ietech »
