Author Topic: even more mystery pliers  (Read 3556 times)
Offline WiebeLC
« on: August 29, 2012, 02:20:55 PM »
These pliers say patent pending, but I can't see a makers mark. Does anyone know if a patent was ever awarded, or who made these?
Re: even more mystery pliers
« Reply #1 on: August 29, 2012, 04:13:02 PM »
I'm thinking another set of glass pliers, if the jaws remain parallel.
Offline Mac53
« Reply #2 on: August 29, 2012, 11:07:44 PM »
I think it is a saw set? ... Very similar to many I saw (and took one home with me) in Belgium. I was told they were "To fix the blades of scissors", but I don't think that was quite the right word he was looking for.
-Marcus-
« Reply #3 on: August 30, 2012, 01:17:32 AM »
The jaws look too narrow to be glass pliers, and why the spring?  Saw set crossed my mind too, but I think we need some pictures taken from  different angles to identify this.
Offline Mac53
« Reply #4 on: August 30, 2012, 07:54:40 AM »
Assuming they are the same as mine, the screw adjusts how far the handles can close and the spring holds back the other much smaller moving jaw. The 2 long portions don't move, and then you can squeeze down a little jaw into the more open section (Maybe more open so that you can then slide out the now angled tooth?)
-Marcus-
Offline amertrac
  • ny mountain man
« Reply #5 on: August 30, 2012, 09:39:08 AM »
question.  are staples or drilled holes and wire holding  the pliers to the plywood?
   bob w.
Online Lewill2
« Reply #6 on: August 30, 2012, 04:26:50 PM »
I agree with Mac, I think it is a saw set also.
Bob, I think it looks like holes were drilled and they used wire to mount them to the board. It looks like drill chuck dimples around the wire holes.
Offline WiebeLC
« Reply #7 on: August 31, 2012, 01:22:07 PM »
All of the tools in the collection have been wired to the wall to prevent them disappearing. Hopefully there will be time to find a better solution for next summer. There is way more stuff to do here than three employees and a few volunteers can keep up with.
« Reply #8 on: September 01, 2012, 03:06:11 AM »
Saw set - this type is common in Europe, especially Germany... Image shows a pair next to the UK type made by Eclipse.
Offline WiebeLC
« Reply #9 on: September 18, 2012, 02:50:12 PM »
I went and looked at the object in question again last week. The jaws don't move. Squeezing the handles causes a projection (about a quarter of an inch long) to move through the jaws(sorry I'm not describing this very well) I wish I could get them off the wall to check the other side for a manufacturer's name but that's not an option right now. Hopefully we will be able to do more with the collection this coming summer. There must be a better way to display them without making it easy for the pieces to be stolen?
« Reply #10 on: September 18, 2012, 05:05:48 PM »
Sorta sounds like a button tool, jaws stay put, a pin pushes through, the pin was to squish over tabs inside the button to lock it to the fabric, several variations on button fastening pliers exist....
Could also be a special rivit tool....
Offline Mac53
« Reply #11 on: September 18, 2012, 10:20:46 PM »
That's how my sawset works as well. Pretty positive that is what it is.
-Marcus-
« Reply #12 on: September 20, 2012, 03:55:14 AM »
Yes, saw setting pliers - try Google images and then try 'pinces à avoyer' (FR) or 'Sägenschränkzang' (DE) for more images to confirm this is a pattern common in Europe...
« Reply #13 on: September 20, 2012, 08:10:28 AM »
A fancier model (about to end on eBay) that I think we had other pictures of here on tool talk not long ago.
Saw Set
