Author Topic: krauter ID  (Read 2447 times)
Offline stormking
krauter ID
« on: August 20, 2012, 11:54:52 PM »
I thought I knew what these are but could be wrong. Anyone know for sure? Not talking about the Bonney Stilson.
By stormking3 at 2012-08-20
Offline Provincial
Re: krauter ID
« Reply #1 on: August 21, 2012, 12:41:55 AM »
They are called "arch punches" and are used to punch holes in leather or rubber belting.
Offline anglesmith
Re: krauter ID
« Reply #2 on: August 21, 2012, 01:49:09 AM »
I've always called them wad punches. A term that I thinks comes from the time of the flintlock muskets/rilfles?
Graeme
Re: krauter ID
« Reply #3 on: August 21, 2012, 03:52:59 AM »
Wad punches in the UK - same reason -  my mate used them to cut new pads for concertinas (the tiny valves that open when you press a button and lets the reed sound)
Re: krauter ID
« Reply #4 on: August 21, 2012, 06:12:43 AM »
We called them hole punch, to punch gaskets to match bolt holes.
granted it would build-up a "Wad" of material inside & had to be pushed out from the top.
I just found a pipewrench like yours Bonney, wanted some background info on it?
Offline stormking
Re: krauter ID
« Reply #5 on: August 21, 2012, 10:45:59 PM »
Thanks all, I first thought they were gasket cutters but they are so heavy duty it didn't add up. I think  belt cutter or leather would be right. The Bonney I don't know anything about other than Alloy says 20's.
