Author Topic: Tansmission Band & Gasoline Line Wrench  (Read 4104 times)
Offline Wrenchmensch
« on: August 04, 2012, 02:21:32 PM »
This 8-inch DOE wrench is stamped Transmission Band toward the 3/4" left open end, and Gasoline Line toward the 11/32" right open end.  I cannot decipher the makers mark, but it might be TFC - CFT - TCF ?  The wrench is also stamped MADE IN USA.
I don't know whether this was an after-market wrench or an original equipment wrench.  Can any of you guys supply more information about this wrench?
Re: Tansmission Band & Gasoline Line Wrench
« Reply #1 on: August 04, 2012, 02:49:40 PM »
CTF was on alloy artifacts 'mystery brand' page for ages, but eventually determined to be a non advertised Herbrand brand.
Suspected date range 1910-1920
http://home.comcast.net/~alloy-artifacts/herbrand-van-chrome.html#cft
« Reply #2 on: August 04, 2012, 06:45:05 PM »
Thank you, Rusty!!!!
« Reply #3 on: August 06, 2012, 01:52:12 PM »
It would seem that this wrench was probably aimed at Ford Model T owners as the transmission band opening on the wrench is the same (3/4") as the closed end opening on Ford 3Z-2034 Model T transmission band ratchet wrenches.
