Author Topic: parts of a tool?  (Read 3740 times)
Offline bigdaddie47
parts of a tool?
« on: July 14, 2012, 12:34:38 AM »
I found these in a bottle when I was cleaning up and resorting my workbench. Not sure where they came from. the Outlined Square one has "ADAMAS THERMILL" on the back. I checked google and found lots of trademark sites and reference to carbide machining but they were all about legal stuff. They are iron with a finish on them. Useful? or fishing sinkers? Thanks to all the gentlemen who have helped me before.
« Last Edit: July 15, 2012, 07:28:37 AM by Papaw »
Offline strik9
Re: parts of a toll?
« Reply #1 on: July 14, 2012, 12:46:49 AM »
Those cutting bits for metal working machines.   I have used a brake drum lathe that uses the triangle type for surfacing the drums.
Those can be quite costly new.
« Reply #2 on: July 14, 2012, 03:31:28 AM »
Replaceable carbide tips for lathe tools - each shape would have its own holder, to which the tip is held by a high tensile screw..
Offline superzstuff
« Reply #3 on: July 14, 2012, 08:37:29 AM »
Most of them are titanium coated indexable milling cutter inserts. I used these for many years on Hurco CNC machines and Bridgeport mills. I still have many of the cutters which use from 1 to 6 inserts. Very expensive.
« Last Edit: July 14, 2012, 08:47:17 AM by superzstuff »
Offline Ken W.
« Reply #4 on: July 14, 2012, 09:20:41 AM »
Defiantly not fishing sinkers.
Offline BruceS
« Reply #5 on: July 14, 2012, 10:49:19 AM »
Not only for metal turning.    If your a wood turner there is a new application.
http://www.easywoodtools.com/
It is not exactly shear turning, more like shear scraping.    I have tested these tools and they are super easy to use and you get a pretty good finish.
« Reply #6 on: July 15, 2012, 03:16:30 AM »
Wood turning chisel:
Offline bigdaddie47
Re: parts of a tool?
« Reply #7 on: July 15, 2012, 11:47:50 AM »
Thank you, Great purveyors of wisdom. Finally something of value in all of my junk. Still haven't found out what my old pump was (canalboat pump was a bust). Now to figure out what to do with them.
« Reply #8 on: July 15, 2012, 02:21:48 PM »
Google up carbide recyclers.
About 3 days after you send them off you'll begin to find things you wish you kept them for.
Offline bigdaddie47
« Reply #9 on: July 16, 2012, 12:27:34 AM »
Aunt Phil, I get in enough trouble with my hand tools much less using big guy machines!!  LOL
Offline Ken W.
« Reply #10 on: July 16, 2012, 09:30:41 PM »
I bought a brake lathe on Craigslist a while ago.The tool bar takes a funky diamond shaped bit that cost $60.00 each. I just had a friend make me another bat to take the triangle bits that are only $30.00 for 6.
« Reply #11 on: July 16, 2012, 10:17:37 PM »
The white diamond-shaped one near the upper right looks to be ceramic. Harder than carbide, but much more brittle.
You can scratch glass with any of those bigdaddie, should you ever get a hankerin' to.
