Author Topic: press or puller?  (Read 2804 times)
press or puller?
« on: July 11, 2012, 01:33:17 PM »
An odd piece I paid a fair price for,needed to know what it was.
The built in wrench makes me think it was for a specific purpose,not
a universal tool.The sliding collar locks the jaws ,and the shaft moves forward whan the handles are closed.
My first guess was automotive ,but really no clue.
Anybody ever see or use one?
Thanks Roy
Offline Neals
  • Alberta, Canada
Re: press or puller?
« Reply #1 on: July 11, 2012, 03:06:56 PM »
My first guess was a spring compressor. It doesn't look big enough to be for valve springs if that is an 8 1/2X 11 sheet of paper its on. Looks like it wouldn't apply enough pressure to be a good puller. HMMMM
« Reply #2 on: July 11, 2012, 06:46:49 PM »
Valve guide seal puller?
Offline amertrac
  • ny mountain man
« Reply #3 on: July 12, 2012, 07:37:35 AM »
I would guess a valve spring compresser and holder then a installer just a guess. if it is i sure could have used one a long time ago.   bob w.
« Reply #4 on: July 12, 2012, 07:46:56 AM »
On the left side of the top photo , you can see a shaft potruding. This comes out whan you comprees the handles.Not sure how you would get the keepers in or out with this in the way.
I thought it was a valve spring compressor when I got it.
I've had several dozen in the past ,just don't see how it would work.
thanks for the input
Roy
Offline lazyassforge
« Reply #5 on: July 12, 2012, 10:24:48 AM »
Just a guess, but could it be for pulling the battery cable clamp off the post on an automobile battery?
B. Davis
« Reply #6 on: July 12, 2012, 03:42:15 PM »
Hi B. Davis. It probably would work on the old style cables. I tried it on the new ones on my Ford product and it won't latch on. The cable end is to small.
The wrench size is 9/16" ,most cable nuts were 7/16 or 1/2.
Looking like some kind of tractor tool from the 20's?
Keep guessing
Roy
