Author Topic: woodchoppers tool?  (Read 3541 times)
woodchoppers tool?
« on: June 20, 2012, 02:24:40 PM »
Labelled Snow and Nealley.
2 x 4 inches
two of these came tie wired together
wood splitter?
JUN 214 by skipskip, on Flickr
Offline Neals
  • Alberta, Canada
Re: woodchoppers tool?
« Reply #1 on: June 20, 2012, 03:29:35 PM »
Could be but I would guess "fallers wedges" Once you have sawed into the tree far enough to not damage the saw you drive the wedge in behind the saw to keep it from binding. Hole is so you can carry the wedges on your belt. New ones are of course plastic.
« Reply #2 on: June 20, 2012, 04:04:12 PM »
Never seen one before, kinda looks like a washer was driven into it.
« Reply #3 on: June 20, 2012, 04:22:18 PM »
2x4 inches is too small for a fallers wedge.
   I expect this is a stone splitting wedge.  Slate maybe?
« Reply #4 on: June 20, 2012, 04:46:58 PM »
Snow and Nealy is in Bangor, ME(still!!!) and makes tools for lumberman.  Still make axes, pulp hooks, and other tools.
I believe the wedge was used when they were topping the tree.  e.i.  the lumberjack would start up the tree using climbing spikes.  As he went he would cut the limbs off.  When he started back down he would cut the tree into the required lengths.  These wedges were used during that operation to keep the saw from binding.  The loop had a line on it to keep it from falling to the ground when the section of trunk fell.  This was repeated until the base of the tree was reached and the job finished.  Thus a "topping wedge"
I have a similar one but not as big.
P.S.  Keep in mind the next time you find a nice axe at a flea market and you think the guy wants too much, that a new Snow and Nealy single bit axe was $99.00 last year at the Old Forge Hardware, in Old Forge, NY
Offline Dakota Woodworker
« Reply #5 on: June 20, 2012, 05:47:04 PM »
I agree with Mike. The falling wedges that I have of my grandfathers are much larger measuring 16" long by 4" wide and about 1" thick at the butt.  The eye in this wedge of yours would have a lanyard tied to it and then to the Toppers climbing belt.  Neat find by the way.
Offline RWalters
« Reply #6 on: June 21, 2012, 12:24:08 AM »
I believe Mike is right on the tool ID, but a little off on the use. Top fallers climbed with spikes (tree gaffs) and a belt, lopping off limbs as they went, just as Mike said and they used the wedges when they cut the top off the tree. But they didn't cut the tree into log lengths as they came down. Back in the days of "skyline" logging, a tall tree on a tall hill would be topped and a block attached. Another tree, the tail tree, also on high ground (preferably the next ridgetop) would be rigged the same way and a cable and carriage run between them. Logs were hooked to the carriage and  with power provided by a donkey engine, hoisted up and out to the yarding site. The top fallers job was to top the trees and rig the blocks. It was dangerous work, one risk being the tree "barber chairing" or splitting along the grain when only partially cut through, the top portion laying back like a barber chair. If that happened, the top faller could cut through his belt and hope he could hang on as the tree whipped back and forth while the split portion detached and fell, or do nothing and risk being crushed against the tree if the split extended through the part he was belted to. Because they did a job no one else had the guts to do, or had too much sense to do, top fallers thought pretty highly of themselves. One point of pride for the old time top fallers was that they never took their spikes off anywhere,  not in the bunkouse, not in town. Another trick, once the tree was topped and the block rigged, was to hold their belt out away from the trunk and drop straight down, like falling down an elevator shaft, catching themselves a few feet above the ground by kicking their spikes in.
« Reply #7 on: June 21, 2012, 07:12:24 AM »
Thanks for the clarification.  I stand corrected...always willing to learn.
As you pointed out.  THESE GUYS WERE NUTS!!!!
« Reply #8 on: June 21, 2012, 12:45:14 PM »
I just call them all saw wedges.  They came in quite a few different sizes.  I have some small top wedges like those in my inventory, as well as some much larger ones that weigh several pounds.  I have been told that during the winter, they attached colored streamers in the holes, so that they could find them if they fell in the snow.
