Author Topic: marking out knife  (Read 4847 times)
Offline bird
  • Resident Rambler
marking out knife
« on: May 24, 2012, 05:26:44 PM »
Me again....
    I just bought a marking knife that reads, " 5/8 S-E DEXTER"  and "I P Hyde southbridge, MASS.  Hydex"
Any info?
cheers,
bird.
Silent bidder extraordinaire!
Re: marking out knife
« Reply #1 on: May 24, 2012, 10:58:03 PM »
Hyde and Dexter are both superlative professional brands. Must have been a merger.
 Except they both make really inexpensive starter and hobby products too.
A big line, both of them.
  So, what does layout knife mean?
« Reply #2 on: May 25, 2012, 08:03:29 AM »
Something like this?
« Reply #3 on: May 25, 2012, 08:10:58 AM »
Something for the OCD woodworker, especially in laying out marks for cuts when making furniture.  I like the colt's foot pattern best for this.
Offline anglesmith
« Reply #4 on: May 26, 2012, 02:39:52 AM »
When I did woodwork in high school! They had a sharp point on one end and a small flat blade cut at an angle off the vertical on the other end. Similar diameter steel and length to a normal metal scriber.
Graeme
« Reply #5 on: May 26, 2012, 08:51:47 AM »
Graeme
Now that you mention it, I remember seeing some of those.  And there are traditional Japanese lay out knives as well, as I've seen them, all steel.  Much more efficient in my experience than the sloyd knives that used to be found in manual arts classes.
« Reply #6 on: May 26, 2012, 10:44:24 AM »
The double enders are often for metal, but I have one made for woodworking. Its the same thing except larger and with rosewood slips on the steel middle.
 Actually, any knife you are comfortable with, that allows you access to mark a line where you need to, is a layout knife.
I have some. I've made some. Used "other" knives too.
  Everyone has their favorites. A person is supposed to try out lots of styles and eventually pick your own favorites.
A knife line is finer than a pencil line. Good to put a chisel right in, for the final paring pass too bring a part, whether mortise or dovetail, whatever, to final size.
Not as easy to see though. Some guys use a knife and then rub chalk in the mark for better vision.
   If a sawcut is especially crucial, its common practice to cut the line where you need it and then cut a second parallel angled line in the waste side, over to the original line. This cuts a little strip of wood free.
 It makes a little trench to lay the saw in.
  This always works and makes the sawcut very accurate,
   but its slow and too fussy for regular work where a pencil is close enough.
 A person need to be able to lay out and work very accurately at times (where it shows), and also to casually lay out and work fast at other times. (where the sun don't shine)
        And learn to know the difference.
