Author Topic: Lube tool?  (Read 2623 times)
Lube tool?
« on: May 13, 2012, 09:07:11 AM »
I actually know what this is, but need the proper name.   Let's see how many can come up with it, and why it was used.
Re: Lube tool?
« Reply #1 on: May 13, 2012, 10:43:49 AM »
Zerk fitting tool. Looks like Alemite.
Re: Lube tool?
« Reply #2 on: May 13, 2012, 11:58:57 AM »
Here is the whole grease gun, ever wonder what they used before rubber hydraulic hoses?  The older Alemite twist zerk fitting accepts a modern push zerk end, thought it was rather neat.
Re: Lube tool?
« Reply #3 on: May 13, 2012, 11:27:54 PM »
As memory serves me, and without pawing through a bin full of old grease guns, what you have there is a high pressure gun with a swivel accessory and a changeable tip accessory.  Both were quite expensive back in the 50s.
The changeable tip collar is not a grease fitting engaging tool, different diameter than the brass fitting with steel retaining pins for the nozzle.  It should only index to the male tip on the back of your zerk tip.  That seems to have been done to prevent the greaser from attempting to crowbar brass fittings with the gun.  Given that you have 2 accessories the gun might also have the fitting to engage the refiller mounted on a 20 gal drum.
Before hydraulic hoses there were flex steel "hoses" similar in design to the plastic popit bead coolant lines used on machine tools.  Solid pipes even with swivels could only get the head into so many tight spots.
BTW, the changeable tip gun generally came with a sheetmetal carrier that had sockets to hold either 4 or 6 tip assemblys.
The kit became very unpopular along with the guy who bought it rapidly when it was realized it allowed greasers (often not the smartest workers) to grease everything they passed on the line with the same grease.
You haven't enjoyed life till you have the joy of a 10hp 3Ø motor with a couple pounds of grease in each bearing area.  I've been on many jobs whert all the motors had 1/8 pipe plugs in place of the grease fittings.
Re: Lube tool?
« Reply #4 on: May 14, 2012, 06:26:11 PM »
Eeek, don't get me started, the local oil change idiots decided to also grease one of the company trucks that someone took over for an oil change. Blew out the seals on every ball joint on the front end. Grrr.....
What do they teach these guys? grease it till the gun runs dry?
Re: Lube tool?
« Reply #5 on: May 14, 2012, 11:11:24 PM »
Auto greasers may be smarter than their industrial brothers.
Either way, NEVER let either find out there are 13 zerks on your Bostrum torsion bar seat.
Offline ron darner
  • RIP 4-18-1941- 9-30-2014
Re: Lube tool?
« Reply #6 on: May 17, 2012, 05:36:44 PM »
Rusty -
The local automotive lube guys are using pneumatically-powered guns that won't run dry for a VERY long time.  Some of them monitor the quantity dispensed - I believe I've seen one that provided a paper printout - so that the shop can charge by the ounce.  That ounce may well cost what you'd pay for a full tube for your manual gun . . .  but they can claim that it includes the equipment usage and labor.
