Author Topic: tap/die/reamer , and a what ?  (Read 4606 times)
Offline RedVise
« on: April 26, 2012, 08:33:38 PM »
Drove a good ways, got lost, bought 4 tool boxes and a plastic container of couldnt sell yard sale junk for $20, as I had a lot of miles invested... dumb.
But as I was emptying out one of the boxes I noticed an embossed logo, turned out to be a late 30s/40s Snap On K-25. And I pulled out 4 Grobet needle files that I will do OK on, so maybe not so bad.
So,  what are these ?  Small ones are slottted to turn XXXXX ? And the other one looks like a tap/die, OK, but a reamer also ?
Any and all help is appreciated !
Brian L.
Re: tap/die/reamer , and a what ?
« Reply #1 on: April 26, 2012, 09:10:54 PM »
Red handled ones look like contact adjusters for Stromberg XY telephone switches.
Not sure on the one with the knurled handle, might be a telephone relay rack wrench.
Bottom one is a battery post & cable cleaner
Offline fflintstone
  • Former master curmudgeon
« Reply #2 on: April 26, 2012, 10:23:00 PM »
looks more like a tire valve tool to me.
Offline nick
« Reply #3 on: April 26, 2012, 10:26:11 PM »
Grease zerk wrench??
« Reply #4 on: April 27, 2012, 05:48:59 AM »
Not sure of the thread size - but if 26TPI probably a gas thread - do not know about the US, but in the UK gas fitters used a combination tool (tap, die and internal reamer) to clean up damaged threads when fitting gas lamps etc - however your tool looks a little modern as gas lamps disappeared c WW2...
« Reply #5 on: April 27, 2012, 08:02:07 AM »
The contact bender with the knurled handle - I have one in my tool box. I don't know what its for, I thought it was for auto ignition. Al.
Offline BruceS
« Reply #6 on: April 27, 2012, 09:21:37 AM »
I agree with grease zerk wrench.  I have and use one.
« Reply #7 on: April 27, 2012, 10:22:33 AM »
The small slotted tools  look like the ones we would adjust the contacts inside the pre-electronic auto voltage regulators.    Had to set them for volts and amp output, plus the cut-out relay.
« Reply #8 on: April 27, 2012, 12:21:17 PM »
I aggree with nick and  Brucec, grease nipple wrench. The spiral portion of the handle is an extractor for removing broken ones and the slot in the side of the hex head is so that it will fit 45 and 90 degree nipples.
Offline RedVise
« Reply #9 on: April 27, 2012, 02:38:37 PM »
Thanks !!
2 questions on this answer ( As always, Thanks for replying !! ).
  The reamer would have to be a left handed thread to be a removal tool ?
  The open end of the tool has what appear to be die threads in it , so I dont see how they would work on an angled fitting.
I think it is a little big for a grease fitting tool, will measure the Tap end tonight. Unless this is a tool for large grease fittings (Wild Ass Guess here).
Brian L.
« Reply #10 on: April 27, 2012, 07:22:51 PM »
No question it is a grease fitting tool.
The Lincoln model you can still buy new today specs are Fitting End (In.) 1/8" to 28" FNPT for use with 1/4-28 Threads
Offline BruceS
« Reply #11 on: April 27, 2012, 08:48:46 PM »
Thanks !!
Brian L.
Grease fittings come usually in one of two sizes(threaded section)  This one looks to be the larger size.
« Reply #12 on: April 27, 2012, 09:35:55 PM »
Below is a link to the smaller size where it could be purchased new.
Short description:  "Small 4 Way Grease Fitting Tool"
Long description:  "Features and Benefits: Combination Tool For Removing Worn Or Broken Fittings For Tap Repair Of Damaged Threads ( 1/4"- 28) For Removal Of Both 3/8" and 5/16" Hex. Straight Or Angle Fittings For Retapping Holes For New Fitting Installation"
http://www.newegg.com/Product/Product.aspx?Item=09S-001Y-000F1
Offline RedVise
« Reply #13 on: April 29, 2012, 07:14:16 AM »
There it is, no doubt!  Wow, $20 shipped for one of these!
If any one needs one, I will drop that in a flat rate box for you, all of $6 !
Thanks to all !
Brian L.
