Author Topic: Keen Kutter #KT6  (Read 3300 times)
lzenglish
  • Guest
Keen Kutter #KT6
« on: June 05, 2011, 09:21:53 PM »
Its a weekend of first finds for me, so here is another one, "KEEN KUTTER #KT6, USS". Much like the Winchester I posted, google does not offer much info on it. The design of this wrench has to be an aquired taste, IMO. It is either beauty or the beast, with it's unusual profile. I'm going to take a guess at 20's or 30's vintage. Any additional info appreciated.
Thanks,
Wayne
Re: Keen Kutter #KT6
« Reply #1 on: June 05, 2011, 09:40:52 PM »
That is an odd offset.
Offline Wrenchmensch
« Reply #2 on: June 09, 2011, 03:11:36 PM »
If the angle of offset is 22 1/2 degrees, these wrenches are known as textile (machine?) wrenches around here (Delaware Valley USA). I spent a short 6 months in a textile plant before being drafted in 1963, but I don't recall seeing any wrenches like this in use.  Someone else on this site may have more of the scoop on this.
« Reply #3 on: June 09, 2011, 07:46:00 PM »
Hmm, I had replied to this post, but the forum ate it : (
Yes, it is a textile pattern, they were offered to mechanics as well as well as loom fixers, but auto mechanics don't seem to have liked them very much..
The odd offset isn't very helpfull on an automobile, but it works well for getting at frame bolts in a loom. Most things in textile machinery are square, rectangular, or assembled at right angles to other things mounted in or on the frame, so a wrench that points straight+ with a small  offset works generally well. On the other hand, almost nothing in an automobile is at right angles to anything else - P
Also, if you try using it on a stubborn bolt sometime, you will discover its other redeeming feature....it likes knuckles...the shallow offset virtually guarantees that if you push on it with the head reversed, it will slip off the bolt, planting your knuckles into the nearest hard object...
They are hard to date generally, the pattern is at least as old as S-wrenches, and they still appear in catalogs  into the 40's....
lzenglish
  • Guest
« Reply #4 on: June 09, 2011, 07:54:34 PM »
Thanks for the Info. Guys.
Wayne
