Author Topic: Size to scan catalogs at  (Read 3883 times)
Offline B17E1943
« on: February 26, 2012, 05:47:13 PM »
I'm wondering what the best compromise between quality and size is for scanning catalogs? 300 or 600 DPI, or? Seems like 1200 is WAY too big, and it magnifies imperfections too much.
Thanks!
_______________________________________
David
Re: Size to scan catalogs at
« Reply #1 on: February 26, 2012, 06:07:40 PM »
No one has grumbled at mine that were scanned at 300 dpi. I reduce the scan size to 1100 pixels wide because it is just a little bigger than full screen size and the fine print does not get lost. Maybe Papaw and LG should weigh in on this one, they've been at it longer than I have.
« Reply #2 on: February 26, 2012, 06:28:39 PM »
I think 600 is enough.
« Reply #3 on: February 26, 2012, 07:21:31 PM »
150dpi has been working well.
For instance, the 1952 MAC catalogue and the 1954 Walden catalogue I recently posted were scanned by Eric at 150dpi. If higher, I often have to do a lot of photo editing to reduce the size before compiling a PDF...
« Reply #4 on: February 26, 2012, 08:05:15 PM »
It is going to depend how large the catalog is too, a small 3x5 catalog should be scanned higher..
The 'theoretical' resoloution of the screen is 72DPI , so anything over that should be readable at least. (720 pixels on a 10 inch wide screen...))
pdf (really JPEG) compression is going to throw a lot away above 300 dpi regardless, unless you make gigantic PDF's..
Offline Fins/413
« Reply #5 on: February 27, 2012, 07:34:43 AM »
I scanned one at 300 dpi and the files were huge, I used 150 dpi on the Mac and Walden I did and I think they are a good comprimise.
1959 Chrysler New Yorker
1982 E150 Ford van
Offline B17E1943
« Reply #6 on: February 28, 2012, 12:50:24 AM »
Sounds like 150-300 DPI is the ticket. Thanks, everyone - I appreciate it.
David
