“You can use an eraser on the drafting table or a sledgehammer on the construction site.” - Frank Lloyd Wright
The Faucet Handle Puller allows you to remove stuck faucet handles from old showers and sinks. The adjustable clamp design works on both small and large handle sizes up to 3” in length. The drive shaft is made from forged steel.• For removing stuck faucet handles from sinks and showers.• 3” adjustable forks.• Forged steel shaft with T-handle grip.Instructions:1. Remove center mounting screw from faucet handle.2. Attach Faucet Puller to handle, with shaft running into the center hole of the handle and the forks around the base of the handle3. Tighten down clamp to pull handle free.
