Author Topic: Unique wrench, but what's it for?  (Read 14503 times)
Offline Wrenchmensch
« on: January 20, 2012, 02:25:33 PM »
I bought this wrench because it was unique, and I am a sucker for uniqueness. The jaw openings only adjust 1/4 inch, from a 1/4" opening to a 1/2" opening. The jaw surfaces are uniquely patterned and bolted in. The hex opening is 1 1/4".  The embossed legends on the handle are "COMBINATION WRENCH" and "SUPERIOR". What I take to be the manufacturer's logo appears to an S surrounded by a circular H(?).
I am mystified as to why this wrench was made. If form follows function, then the wrench's jaw surfaces seem ideally suited for gripping a fixed-dimensioned surface such as plywood used in large-form concrete molds. It's conceivable that one or two men could grab and locate a large plywood mold board using these wrenches. One of the wrench's four shaped openings may have gripped rebar fasteners used to secure both ends of the rebar to the outer sides of the plywood before the pour.  The foregoing is pure speculation, of course.
What do you guys think this is?
« Last Edit: January 27, 2012, 11:54:58 AM by Wrenchmensch »
Offline Nebraska Cowman
Re: Unique wrench, but what for?
« Reply #1 on: January 20, 2012, 08:30:26 PM »
Your post gave me a clue. Is it a sucker rod wrench?
« Reply #2 on: January 21, 2012, 12:58:03 AM »
The hex opening looks to be about the same size as the vertical shaft sticking out the top of some fire hydrants but I can't think of anything else related to a fire hydrant that the top jaws would fit ?
« Reply #3 on: January 21, 2012, 06:19:39 AM »
Your post gave me a clue. Is it a sucker rod wrench? -Nebraska Cowman
I have sent an email to the president of a sucker rod manufacturing company asking him if this is a sucker rod wrench.  It doesn't look like a modern sucker rod wrench though.  We'll see.
« Last Edit: January 21, 2012, 06:22:29 AM by Wrenchmensch »
Offline sumner52000
« Reply #4 on: January 21, 2012, 01:37:05 PM »
My co worker says fire hydrant wrench.
Offline Neals
  • Alberta, Canada
« Reply #5 on: January 21, 2012, 01:53:12 PM »
Superior Tool Co makes plumbing tools but I couldn't find anything similar to yours.
Online skipskip
« Reply #6 on: January 21, 2012, 03:23:49 PM »
Hydrants usually have 5 sided valves to keep yahoos from opening them.
that is one VERY cool wrench
Skip
Online skipskip
« Reply #7 on: January 21, 2012, 03:24:43 PM »
Oh, my guess is gas line work, from the oval slot at the end.
Skip
Offline mrchuck
  • retired Federal LEO Ranger
« Reply #8 on: January 21, 2012, 04:53:05 PM »
Gas meter cut-off, fire hydrant opener, and a spring loaded  adjustable monkey, painted RED,,,, tells me it is a Fire Dept wrench that goes to fire scenes with firemen.
Molon Labe
« Reply #9 on: January 21, 2012, 05:18:30 PM »
My son, the firefighter says it is not a hydrant wrench.
« Reply #10 on: January 21, 2012, 09:31:02 PM »
Definitely not fire hydrant, as it isn't long enough. I've turned one or two of those in my time as a vol. firefighter. Those stems can be stubborn to get broke loose. I've also broke a couple stems, due to the water dept. not servicing the valve as they should have allowing the stem to seize up.  They are also, as mentioned, pentagonal in shape to deter water thieves and vandals.
I'm in the gas line work group on this one, as the slot could very well be for turning off small meter valves. Still not sure what the small range jaws would be for, though.
« Reply #11 on: January 21, 2012, 09:45:02 PM »
What was gas pipe made of, lead, copper, steel, or iron?
« Reply #12 on: January 21, 2012, 09:47:55 PM »
The big stuff was cast iron, the little stuff was malliable iron , later steel.
The type of jaws on that wrench seem to me to be for turning rod, or bending something flat, they would make a mess out of pipe
« Reply #13 on: January 22, 2012, 12:22:41 PM »
Quote
These jaws would not cut as deep as conventional pipe wrench jaws do.  The projections on this wrench's jaw faces is less than 1/64". Would they leave a shallow crosshatched pattern on a pipe or rod surface?  Probably.  If this wrench was intended for pipe use, the pipe's OD would have to be between something like 5/16" and 1/2" and that pretty small.
Re: Unique wrench, but what for? A
« Reply #14 on: January 22, 2012, 01:01:47 PM »
Following is the response I got from the CEO of a sucker rod manufacturing company about this mystery wrench:
Mr. Wickes,
I can’t imagine how this wrench would be used with any modern configuration of sucker rods which are 5/8 through 1 1/8” inches in diameter.  However, sometime in the past ½” diameter rods were used and the wrench appears to function like a pipe wrench, so maybe it was used on early sucker rods.  Today, it would not be acceptable if it damages the surface of the rod.  Prior to all steel rods, wooden rods were used with steel ends for connecting them together. Again I can’t imagine using this wrench for the wooden ones either.  I am afraid I am not much help, but will ask around.
Bill Ridenour
