Author Topic: Armstrong 1/4" set  (Read 4761 times)
Offline sumner52000
Armstrong 1/4" set
« on: January 05, 2012, 02:25:35 PM »
I have an Armstrong 1/4" set I picked up a while back. I was wondering if it is complete or if I have missing/extra pieces. Does anyone have a catalog with this listed, or any other info? I'm guessing it is from the mid 1950s.
Here is what I have:
Ratchet NMA-51
Breaker NM-A2
T- handle? NM 42B
1/4-3/8 adapter MF-130
Sockets
3/16
7/32
1/4
9/32
5/16
11/32
3/8
7/16
1/2
Offline lauver
  • Belton, TX
Re: Armstrong 1/4" set
« Reply #1 on: January 05, 2012, 03:00:22 PM »
I think you have a near complete tool complement in your set.  The range of sockets looks correct.  The ratchet and flex handle match.  Not sure about the T-handle/cross bar (this is likely a cross bar for your flex handle). Does the flex handle have a female drive on the end of the handle?
I'm guessing there should be at least one extension or a spinner handle that doubles as an extension (perhaps 6").
« Last Edit: January 10, 2012, 02:32:57 PM by lauver »
Offline sumner52000
« Reply #2 on: January 05, 2012, 03:25:12 PM »
"Not sure about the T-handle/cross bar (this is likely a cross bar for your flex handle). Does the flex handle have a female drive on the end of the handle?"
Thats right there is hole it slides through and a detent ball to hold tight.  Don't know why i didn't see it before.  Thanks.
Next question would be what size extensions and what part #'s.  I guess a 3" would be common anything else?
Offline Fins/413
« Reply #3 on: January 05, 2012, 04:51:57 PM »
Man you got a dandy set there.
1959 Chrysler New Yorker
1982 E150 Ford van
Offline Fins/413
« Reply #4 on: January 07, 2012, 07:11:34 AM »
Sumner I have a 1948 catalog that has the NMA-51 ratchet listed but it the older flat style handle not the round one. I also have an older catalog from C-39 (1939?) that shows a NM-51 ratchet with that style handle, 4" long. Yours looks like it might be a little longer.The logo doesn't look right though. Thought I'd do my best to muddy the waters. The logos from either catalog doesn't look like the one you have.
1982 E150 Ford van
Offline sumner52000
« Reply #5 on: January 07, 2012, 08:26:09 AM »
Thanks guys.  I picked up the set at an estate auction of an engineer.  I saw this pictured in the auction listing so i made the 45 min ride.  Then i spent almost $1000.  Got the wife a nearly new washer and dryer, and several boxes of tools.  Most of the tools were snap on and blue point supreme.  I was making my mid 1950's guess because of the date codes of 1955, and 1956 on the snap on stuff.  Also picked up several of the octo-grip screwdrivers.
Offline m_fumich
« Reply #6 on: January 07, 2012, 09:14:58 AM »
I hope the majority of that $1000 was spent on tools. When my wife needed a new washer and dryer, I got her a rock to best the clothes on and a line to hang them on. Let me tell you this. Do not piss a woman off and give her a rock to knock you out with and a rope to tie you up.
« Reply #7 on: January 08, 2012, 12:14:22 AM »
That ratchet sure looks like Proto made it. I have a 3/8 Armstrong ratchet and the parts interchange with a Proto 3/8 ratchet.
