Author Topic: What's this?  (Read 3004 times)
Offline ctarborist
What's this?
« on: January 02, 2012, 06:10:43 PM »
A friend keeps digging these items up in his yard in Southbury CT.  They're made of aluminum, apparently hold a wooden insert of  some type.  Those rivets are copper.  The aluminum pieces are joined with a 1/2 inch stud insert.  I suspect these are bracing devices of some type, but any ideas are appreciated.
Re: What's this?
« Reply #1 on: January 02, 2012, 06:12:12 PM »
Can we see the other end?
Re: What's this?
« Reply #2 on: January 02, 2012, 11:56:49 PM »
Is that aluminum or zinc plated?  They look alot like the business end of wind mill pump rod.  Some of the early pumps had  wooden shafts joined in sections with iron couplings, to lift the water.  Just my thought.
Re: What's this?
« Reply #3 on: January 03, 2012, 12:20:15 AM »
Found it!!
Wood sucker rods for windmills is correct-
Quote
WHITE ASH WOOD ROD
Windmill Catalog Page 60
   $ 4.40 ft.    1-1/8"    1-1/8"  White ash wood rod with galvanized steel couplings
               ( 5/8" threading )
   $ 6.30 ft.    1-3/8"    1-3/8"  White ash wood rod with galvanized steel couplings
               ( 7/8" threading )
Octagon white ash wood sucker rod with galvanized steel couplings and copper rivets comes in random lengths.
The 1-1/8" wood rod has 5/8" box and pin (threads), weighs 50 lbs cft, and comes 9 lengths to a bundle
( approximately 180' ).
The 1-3/8" wood rod has 7/8" box and pin (threads), weighs 80 lbs cft, and comes 6 lengths to a bundle
( approximately 120' ).
http://www.deanbennett.com/rod.htm Scroll down the page about 3/4 of the way.
Re: What's this?
« Reply #4 on: January 03, 2012, 08:41:09 AM »
Good work boys!
Re: What's this?
« Reply #5 on: January 03, 2012, 12:21:38 PM »
Makes you wonder if someone might have had a pile of the rods stacked up for storage, and the wood rotted away leaving the scattered ends to be found decades later!!!
