Author Topic: Craftsman Special Purpose? What for?  (Read 13401 times)
Offline kxxr
« on: December 31, 2011, 09:53:37 PM »
I haven't seen this one before. I did try to find it in a couple of older catalogs but couldn't see it there. It looks like mid 60s vintage maybe but I don't know. Can anyone tell me about this one?
Re: Craftsman Special Purpose? What for?
« Reply #1 on: December 31, 2011, 09:55:59 PM »
Just a blunt end?
Offline kxxr
« Reply #2 on: December 31, 2011, 10:02:41 PM »
It's blunt but not flat. Conical I guess.
« Last Edit: December 31, 2011, 10:07:05 PM by kxxr »
« Reply #3 on: December 31, 2011, 10:23:20 PM »
Might be a burnisher.
Offline Tool Pants
« Reply #4 on: January 01, 2012, 04:30:16 AM »
Looks like a super-tuff handle.  Don't know what it is.  Do not remember seeing a burnisher in the old catalogs.  Maybe a screwdriver with the tip cut off?  Any other markings on the handle.
« Last Edit: January 01, 2012, 04:31:50 AM by Tool Pants »
Offline KeepinOldBolts
« Reply #5 on: January 01, 2012, 09:40:20 AM »
I'd venture a guess at socket cross bar, but don't recall Cman sockets having that opening.
Offline kxxr
« Reply #6 on: January 01, 2012, 10:13:10 AM »
It's a bit fat and heavy for a screwdriver, with the diameter being about 3/8". Overall length is just 8". I suppose it could have been a much longer shaft that has been cut, as mentioned,  but if that were so I would expect the handle to be larger for a shaft this size.
I couldn't see any other markings other than the Craftsman name. I even held it in the light to see if there was a number or anything that used to be there but had just lost it's paint. I could not see any sign of that either.
Offline kxxr
« Reply #7 on: January 01, 2012, 11:04:57 AM »
I wasn't sure what a burnisher is, but I looked it up and I think you have it. I'll go with that, it makes sense. I'll try a little harder to find one in the catalog with that info. Thanks.
Offline lauver
  • Belton, TX
« Reply #8 on: January 01, 2012, 11:21:36 AM »
kxxr,
Could it be a sharpening steel for putting a fine edge on a knife?
The handle is pre-1960, perhaps pre-1950.  Is there a series code (makers mark) on the handle?
« Reply #9 on: January 01, 2012, 03:53:44 PM »
The blade doesn't look long enough to be a sharpening steel to me...
Offline BruceS
« Reply #10 on: January 01, 2012, 08:29:51 PM »
Could be as simple as a phillips that never made it to the final grind.
I have found the small insert type tips that didn't make the final grind either.
« Reply #11 on: January 01, 2012, 09:58:11 PM »
Even though I have not seen one that new, it looks like a burnisher to me.
Burnishers are made with very hard steel.  You could ee if you can scratch it with a piece of steel.
Offline Tool Pants
« Reply #12 on: January 02, 2012, 12:08:30 AM »
Sears did have a sharpening steel, but this is only a few years ago.  I think it was WF.
« Reply #13 on: January 02, 2012, 05:33:37 AM »
And notice how much longer the blade is on TP's steel...
« Reply #14 on: January 02, 2012, 06:37:39 AM »
I'm going for burnisher -- for working scraper blades.  I've never seen one with a plastic handle, but the dimensions look right.
