Author Topic: Stove wrench or lug wrench?  (Read 3120 times)
Offline superzstuff
« on: December 16, 2011, 10:18:24 PM »
I bought a box of Ford A and T wrenches and this wrench was in with them. Marked only with a "15", it has a diamond shaped opening that may be worn that way. Opening measures 3/4" across flats. Looked large for a stove eye lifter, but not sure.
Re: Stove wrench or lug wrench?
« Reply #1 on: December 16, 2011, 10:26:30 PM »
lug wrench / tire iron?
is it welded near the socket end?
Offline superzstuff
« Reply #2 on: December 16, 2011, 10:46:49 PM »
No, that is where the number 15 is located. It is all one piece.
Offline Neals
  • Alberta, Canada
« Reply #3 on: December 17, 2011, 01:01:58 AM »
I don't have my stove wrenches handy to check but as I recall they are 3 sided with rounded corners. My guess would be some kind of valve wrench. I doubt that it is wore very bad. In the last pick it looks like the top face  is longer than the 2 sides joining joining it and they all look crisp and not worn.
« Reply #4 on: December 17, 2011, 11:06:05 AM »
I would say it is a stove shaker grate handle/lid lifter combo. Pretty commonly found amongst tool lots, most people that have never seen one assume it is a mechanical tool based on the socket end. Note the way the "pry bar" end is made. Old wood stoves had flat iron plates on the top, with a recessed area near the edge with little bars across the hole to insert the bar to lift them out to add wood or check the fire.
Also, the socket is more like a triangular shape, as mentioned by neals. That is also a common trait with shaker handles.
Offline Stoney
  • New Market, Alabama
« Reply #5 on: December 21, 2011, 05:27:09 PM »
I agree Keykeeper.  The lifter end tells the tale.
Hobbit"
-Thomas Edison
