Author Topic: Estate Sale 6/21/2024  (Read 2311 times)
Online Yadda
« on: June 21, 2024, 07:36:06 PM »
Today's estate sale buy.  The socket set is a Hinsdale TL10.  The DBE wrench is a Lectrolite Defiance.  The 12-inch adjustable is a Williams Superadjustable.  The tap handle is a Greenfield No. 6. Hidden right in the middle is an early Craftsman 1/4 breaker bar.
Re: Estate Sale 6/21/2024
« Reply #1 on: June 22, 2024, 07:15:00 PM »
Is that a Starrett Plumb Bob? Filled or solid steel?
Online Yadda
« Reply #2 on: June 22, 2024, 08:44:12 PM »
Wow!  Good eye! I didn't realize it was a Starrett until I did a little cleaning.  It is a Starrett  No. 87. It isn't solid.
« Last Edit: June 22, 2024, 10:05:54 PM by Yadda »
Online lptools
« Reply #3 on: June 23, 2024, 09:17:11 AM »
Hello , Yadda . The drive plugs in the Hinsdale box are a great find! Are they marked?
« Reply #4 on: June 23, 2024, 10:25:06 AM »
If it is an 87, it should be mercury filled unless somebody emptied it. If you shake it you should be able to feel the mercury moving inside. I think the hex top ones were later production, so they didn't roll when you set them down.
Offline Analog
« Reply #5 on: June 23, 2024, 11:29:49 AM »
Great find. Should produce some fine restorations, If you have the time.
Online Yadda
« Reply #6 on: June 24, 2024, 01:01:16 AM »
The 1/2 drive is marked "Made in U.S.A." . The 3/8 plug isn't marked. The Ratchet on the far left was also included, but was made in China so it was original.to the set.  :grin: I believe I have a Hinsdale Plug style ratchet.  Now I need to find it.
