Author Topic: Lets see how many know this tool?  (Read 3844 times)
Offline Stoney
  • New Market, Alabama
« on: November 30, 2011, 04:36:45 PM »
Ten inches long, made in the 1930's with a stacked leather handle.
Hobbit"
-Thomas Edison
Offline 64longstep/Brian
  • Phoenix Arizona
Re: Lets see how many know this tool?
« Reply #1 on: November 30, 2011, 04:42:23 PM »
Is it a baseball glove lacing tool???
« Reply #2 on: November 30, 2011, 05:01:48 PM »
Grain sack sewing needle?
« Reply #3 on: November 30, 2011, 06:35:02 PM »
I'll go with football lacing tool.
Offline JessEm
  • MinneSNOWta
« Reply #4 on: November 30, 2011, 07:57:52 PM »
It looks like a clock weight but a football lacing tool is winning so far...
Offline Stoney
« Reply #5 on: November 30, 2011, 08:25:37 PM »
There are on markings.  Look at the size of the hole.
Hobbit"
-Thomas Edison
« Reply #6 on: November 30, 2011, 08:39:28 PM »
I am thinking it's for shorting out light sockets.
Tho, I can't think why you would want to do that.
Perhaps a fly swatter for people with really good aim?
I notice the tool is twisted just under the handle, so I'm thinking it is rotated in use a lot....
« Reply #7 on: November 30, 2011, 09:11:32 PM »
I'm remembering a tool something like this for pulling plugs into holes in tires.  Looks too long for lacing footballs and such.
Offline Stoney
« Reply #8 on: December 02, 2011, 05:54:41 PM »
This is a weavers reed hook.  In particular it's my Dad's reed hook when he was a weaver in Lincoln Mills in the middle '30's.  It was also my reed hook when I was a loom fixer in Huntsville Manufacturing in the '70's.
A much older loom but run on the same principles as the 1898 looms I ran except ours had 4 harnesses instead of 2.
In the upper right is the shuttle.  It is running in the shed and in that position is going over 100 miles an hour and is traveling on the lathe.  The vertical bars behind the shuttle is the reed.  When the shuttle has boxed, the lathe will come forward against the thread just laid down and pack it tight in the warp threads.  The harness will shift, so that the threads that were up, are now down and down is now up and the shuttle goes the other way.  The loom does this about 88 times a minute.  When a thread breaks the loom stops and the weaver/loom fixer/tie in  will tie in a new thread in a weavers knot (like a surgeons knot) ,clip off the ends and using the reed hook pull the new thread through the right harness slot and the right reed slot and tie to the broken thread.  Then restart the loom.
« Last Edit: December 02, 2011, 05:59:04 PM by Stoney »
Hobbit"
-Thomas Edison
« Reply #9 on: December 02, 2011, 06:35:39 PM »
Wow!  I'm glad to learn about this.
« Reply #10 on: December 02, 2011, 06:58:31 PM »
Thanks Stony :)
I had this feeling it was a textile tool, but I couldn't think what it might be
and didn't go with it :(
So much for trusting intuition ...
Offline Stoney
« Reply #11 on: December 04, 2011, 02:57:37 PM »
I posted in General Discussion more about cotton mills.
Hobbit"
-Thomas Edison
