Author Topic: What are these tools?  (Read 439 times)
Offline bird
  • Resident Rambler
« on: October 27, 2022, 07:28:46 PM »
Silent bidder extraordinaire!
Re: What are these tools?
« Reply #1 on: October 27, 2022, 08:13:22 PM »
The long plier like piece in center of photo is for brake spring removal and install on drum brakes. Probably a name somewhere. Looks like a quality piece.
The other stuff I might be able to guess , but wait for positive id from others.
Glad you got the photos figured out. The pipe with the white insulator looks like a support for electric hook up to house supply.
« Last Edit: October 27, 2022, 08:15:53 PM by Lostmind »
« Reply #2 on: October 28, 2022, 03:20:11 AM »
Far right is a grinder wheel dressing tool.
« Reply #3 on: October 28, 2022, 02:00:29 PM »
The handle just to the right of the white ceramic insulator looks like a crank handle designed to clamp on a shaft, maybe a field repair item - original handle broke, you need to crank the thing the shaft comes out of.  If it's bronze/brass/not steel, it's probably for a boat.
The others not yet named are fairly mysterious to me.
« Reply #4 on: October 28, 2022, 05:35:40 PM »
I agree
« Reply #5 on: October 28, 2022, 05:38:58 PM »
The pipe wrench with thevred jaw looks similar to the Craftsman roller jaw pipe wrench.  Also similar to the Fatkin and Trig-o-matic pipe wrenches.
« Reply #6 on: October 28, 2022, 06:11:46 PM »
Bird, maybe some close-ups of the yet unidentified pieces would help - also note any markings.
Offline JoeCB
« Reply #7 on: November 07, 2022, 04:53:25 PM »
The handle thing, upper left looks like a handle for a milling machine vise. Does the socket swivel? socket for a square shaft?
Joe B
« Reply #8 on: November 12, 2022, 09:55:29 AM »
Does the pipe wrench have J1010 or J1014 on it? The jaw spins 360 to open it then you can ratchet it to fit the size of pipe. I like them but they seem to be very underappreciated.
« Reply #9 on: November 15, 2022, 07:10:42 PM »
Two of those could be Clevis Pin wrenches.
https://papawswrench.com/vboard/index.php?topic=1182.0
