Author Topic: 220 volt Milwaukee Super Hole Shooter  (Read 3167 times)
Offline Brad in Wisconsin
« on: February 25, 2021, 05:08:15 PM »
I just came across this Good Ole Milwaukee drill anyone know about it's odd voltage
Re: 220 volt Milwaukee Super Hole Shooter
« Reply #1 on: February 25, 2021, 05:57:49 PM »
Probably to discourage it getting legs so fast.
Online skipskip
« Reply #2 on: February 25, 2021, 06:53:31 PM »
Euro market? lotsa 220 over there
industrial?  many plants seem to be mainly 220V for single phase
just cause?
Skip
« Reply #3 on: February 27, 2021, 05:40:56 PM »
It's not odd if you consider that a lot of electric drills from that period - maybe the majority - were used in commercial/industrial settings.  220 volt power allows for lighter gauge wire for a given net output, not an insignificant issue if you're wiring an entire factory.
Of course, electric drills from that period often lacked equipment grounds, using the mechanic holding them as the equipment ground if a fault occurred, and the mechanic lights up more dramatically; so there are arguments for 110 volt power, too.
