Author Topic: Stumped on these  (Read 4260 times)
Offline coolford
  • Old as dirt
Stumped on these
« on: December 03, 2020, 03:10:06 PM »
These were in a box lot and thought they were files at first.  However, the triangle shape has sharp edges and a point but no teeth on the edges or sides.  Even more confusing is the one with a wood handle has a Nicholson, warrented, USA mark.  What are they and how used?
Re: Stumped on these
« Reply #1 on: December 03, 2020, 03:16:44 PM »
could it be inside  small hole deburring tool?
« Reply #2 on: December 03, 2020, 03:19:29 PM »
Those are 3 Edge Scrapers, or Machinist's 3-sided Scraper. Most that I have were found in Machinist's tool boxes, for de-burring holes, edges, or, flat surfaces on metal.
« Last Edit: December 03, 2020, 04:35:09 PM by lptools »
Offline Analog
« Reply #3 on: December 03, 2020, 05:05:45 PM »
My thought on these would be bearing scrapers.
« Reply #4 on: December 03, 2020, 05:13:51 PM »
I believe traditional bearing  scrapers are curved, and 2-sided. Not that a 3-sided scraper couldn't be used for bearings!!
« Last Edit: December 03, 2020, 05:20:46 PM by lptools »
Offline p_toad
« Reply #5 on: December 03, 2020, 07:32:42 PM »
i'm going with the 3 sided scraper.   i have an old shorty (like those) and a much longer one i got from a neighbor's yard sale that is probably 8 or 9 inches long (not including handle).
« Reply #6 on: December 03, 2020, 09:09:35 PM »
I’m with Lou, these work great for scraping paint spots off wood or metal too. Lots of different sizes also. The one I use the most is about an eighth of an inch on a side. Keep them sharp!
« Reply #7 on: December 03, 2020, 09:21:32 PM »
And they're dynamite useful tools when sharp.  I own two, and would not want to be without them.  Great for deburring holes and similar edges.
« Reply #8 on: December 04, 2020, 05:57:11 AM »
I use mine all the time. I have two and a third one I made from a triangular file - it took a very long spell at the grinder to make it.
Offline coolford
  • Old as dirt
« Reply #9 on: December 04, 2020, 07:28:33 AM »
Much thanks, now I have another tool to use instead of a file.
« Reply #10 on: December 04, 2020, 07:39:10 PM »
The mechanics scraper sets like Mound made had one in them.
Offline leg17
« Reply #11 on: December 04, 2020, 08:09:46 PM »
Sometimes shop-made from triangular files.
A great many machinists have at least one and find them indispensable.
Offline d42jeep
« Reply #12 on: December 07, 2020, 09:53:31 PM »
I believe that they were used on babbit bearings. One was included in the WW2 machinist’s set. The color pictures are my re-creation of that set.
-Don
« Last Edit: December 07, 2020, 09:55:05 PM by d42jeep »
« Reply #13 on: December 08, 2020, 05:03:43 AM »
Hello, Don. Here is a photo showing the difference between a 3-Sided Scraper, and a Bearing Scraper. Once again, you can use a tool for whatever you need to get the job done, but the photo should clear up how the 2 different tools were designed, and marketed. Stay safe, Lou
Offline d42jeep
« Reply #14 on: December 08, 2020, 07:22:18 AM »
I have both types of scrapers. Like you say, they are used for whatever is required. I often use my three corner for getting burrs out of the inside of PVC pipe.
-Don
« Last Edit: December 08, 2020, 10:00:50 PM by d42jeep »
