What is this for?
Started by kxxr, November 25, 2011, 09:51:09 AM
kxxr
Looks like it would be used to crimp something or other. It looks to be very well made for heavy use. Anybody know what they are for?
Stoney
Hobbit"
-Thomas Edison
Papaw
Will it only work on the end of something, or will the wire or cable or whatever pass through the tool?
I'm thinking battery wire end crimper.
kxxr
Sorry guys, I was checking it out in the pawn shop and don't have any other details at the moment. I did check out the name on it, but of course I don't remember that. I will check it out a little closer when I go back. I was trying to sneak a picture without being noticed. I'm not sure if they would care about that or not but don't wish to find out either.
What drew my attention though, is that it is just one of those tools that you can tell by look and feel that it is well made. I do remember thinking that the name was not familiar to me and is probably a PROC or Taiwan made tool.
Rhoderman
It's a ferrule crimper for wires.  We have used these a lot at work.  It puts an end on wire if you want to make it much more rigid for screw terminals.
Here's a link to some ferrules: http://www.digikey.com/us/en/ph/americanelectrical/wireferrules.html
It's a handy tool, but limited use for most people.  We use a lot of screwdown terminal blocks, and the ferrules make the job look very professional.  If you're using those type of terminal blocks, you don't want to tin the wire as the solder will cold flow and fail later when you least expect it.
Stoney
Hobbit"
-Thomas Edison
bigdaddie47
amazing, always wondered what those things were since they don't come in a multi pak-
kxxr
I got another look at it and it is a Weidmuller PZ6 Roto. Turns out they are kind of expensive to buy, over a hundred bucks on the sites where I found it advertised. The shop had it in the 'garbage' bin along with all the batteries with no tool and tools with no batteries and various other unknowns. I think I may just pick it up if they'll take a buck or two.
