Author Topic: Armstrong Special DOE  (Read 2303 times)
Offline J.A.F.E.
« on: November 24, 2011, 04:23:31 PM »
Just a little oddity I stumbled across. For some reason the awkward proportions are really appealing at least to me. I would really like to know what special application this was intended for but judging from the beefy proportions of the open ends it seems to have been high torque even though the slim beam seems to conflict with that.
Armstrong Armaloy 1/4 X 3/16
Compared to the closest thing I have an Armstrong 1020 1/4 x 5/16. The Special open ends are so so much bigger but the beam is so skinny compared to the 1012.
Compared to the other 1/4 open ends I have to show the beefy proportions. Left to right: Armstrong Special, Armstrong 1020, Bonney Zennel H12 1/4 x 9/32, Bonney H12 1/4 x 9/32, Indestro 894 1/4 x 7/32, Proto 1208 1/4.
All my taste is in my tools.
Re: Armstrong Special DOE
« Reply #1 on: November 24, 2011, 05:43:09 PM »
Most of the major wrench makers supplied 'specials', they were nothing more than non-standard combinations of sizes in most cases. The wrench was probably intended for a machine that only needed those two sizes. Since other machines might also need a wrench with only those two sizes, the wrench makers could make out by offering the 'special' combinations (sans custom lettering) somewhat cheaper than a full contract wrench. Which means your wrench might fit multiple things, particularly as 1/4x3/16 isn't all that 'special'....
I suspect the odd head proportions are more from sticking a 1/4 head blank on a handle originally intended for a smaller head than any indication it was intended for high torque, also, note that the head on the special you have is less circular than the wrench you are comparing it to, I suspect it is a later design....
Offline J.A.F.E.
« Reply #2 on: November 24, 2011, 06:11:28 PM »
Makes sense rusty. Still would like to know what it was intended for but not likely really to find out. Any idea of age?
« Reply #3 on: November 24, 2011, 10:50:35 PM »
Armaloy puts it about 1946-1980, the armstrong logo is square , with no arm, so , off the cuff guess, mid-late 70's...
not much data for that tho....
Offline strik9
« Reply #4 on: November 25, 2011, 02:24:36 PM »
I'll dig around in the boxes some, but I think I have another brand wrench with the odd shaped ends and a thinner shank.  I will agree with the idea of that being made for a special purpose or intention rather than a mechanic's  general use kit.
