Author Topic: Stanley square steel questions  (Read 2238 times)
« on: June 10, 2020, 07:47:44 PM »
I just got a pile o stuff from someone who worked at at the Stanley Plant in VT.
include is some steel he claims was used to make squares
unfortunately all steel looks alike to me so I dont know what kind it is.
so I need a metal expert or a link to a Stanley catalog from the 90's to learn what I have
I also got some squares and other stuff, not much in the way of wrenches
any help??
Skip
Offline papadan
  • Just an old wrench tugger
Re: Stanley square steel questions
« Reply #1 on: June 11, 2020, 09:51:43 PM »
I can't say what type of steel you have, but all squares are made from mild steel. The markings are either stamped or etched and being mild they can be straightened when bent and with a simple punch in the corner the Squareness can be adjusted when needed.
VWs to D10s, I've fixed em.
« Reply #2 on: June 12, 2020, 06:36:31 AM »
I have a fondness for metal squares.  Probably because I get them cheap at yard and estate sales.  I have a small unique one that isn't (square). Now I'll have to try your advice.
« Reply #3 on: June 12, 2020, 09:12:20 AM »
Right: inside if the angle is acute, outside if it's oblique (as measured on the inside of the square).
« Reply #4 on: June 12, 2020, 01:10:33 PM »
Offline papadan
« Reply #5 on: June 12, 2020, 09:23:42 PM »
Never used a transfer punch, just regular old center punches. Works like a charm.
« Reply #6 on: June 12, 2020, 11:59:21 PM »
I agree with papadan, I've fine tuned a couple of squares over the years and and a normal center punch works well but I suppose a transfer punch would also do the job. I can't see any advantage to using a transfer punch ?
« Reply #7 on: June 13, 2020, 01:22:31 PM »
Is it sheet stock for a flat lumber type of square? or  different thicknesses for the machinist's type squares?
« Reply #8 on: June 13, 2020, 04:44:12 PM »
I'm guessing that a transfer punch would give a more consistent indent ( once it has bottomed out).
Offline wrenchguy
    • Wrenchguys videos
« Reply #9 on: June 13, 2020, 07:33:00 PM »
Got any 24"x18"?  Hard to find, most been cut down years back, when platform/western framing took over using 16" centers.
Offline papadan
« Reply #10 on: June 13, 2020, 09:41:08 PM »
[/quote]
I've got a few new ones from HF, cheap but reliable, after checking and adjustment when needed. :-)
