Author Topic: Stevens Perfect pinvise  (Read 11023 times)
« on: May 22, 2011, 07:21:12 PM »
I bought ( AND OVERPAID) this little hand vise because I and the seller alike thought it might be H D Smith. Turns out it is not. Marked Stevens N Y and Perfect.
Question is, is the spring correct? There are holes for the spring to fit in, and it it seems to be installed correctly, but the spring is out of place as I see it.
I have also been unsure of how to used this little hand vise. Any one know anything?
« Last Edit: May 22, 2011, 07:51:50 PM by Papaw »
lzenglish
  • Guest
Re: Stevens Perfect pinvise
« Reply #1 on: May 22, 2011, 07:47:27 PM »
The spring looks out of place to me, as it is blocking the jaws for any work you want to insert, and clamp down on? Could be a special purpose clamp, instead of a hand vise?
Wayne
Offline anglesmith
« Reply #2 on: May 22, 2011, 07:49:45 PM »
It looks remarkably like those early spoke nipple wrenches, there was a thread on the old site! (We are going to get sick of hearing and saying that!) The lower end near adjusting screw doesn't show any signs of being cut off?
Graeme
« Reply #3 on: May 22, 2011, 07:59:08 PM »
Quote
...signs of being cut off?
Now that you mention it, there are rough filing marks there.
And now I am even more upset with myself! Guess my mind isn't working like it should!
Look-
Offline anglesmith
« Reply #4 on: May 22, 2011, 08:08:31 PM »
I'm sure 64longstep of phake fame could make it look like it had never been altered.
Graeme
« Last Edit: May 22, 2011, 10:15:55 PM by anglesmith »
lzenglish
  • Guest
« Reply #5 on: May 22, 2011, 08:46:40 PM »
Well, it looks as though the spring does belong in between the jaws after all.
Wayne
« Reply #6 on: May 22, 2011, 10:51:34 PM »
 yes spring is in right position. Bicycle spoke vise;picture shows Rollfast and Stevens. same design
lzenglish
  • Guest
« Reply #7 on: May 23, 2011, 12:53:31 PM »
So the working, or buisness end of this tool is on the left side, near the thumb screw, is that correct?
Wayne
« Reply #8 on: May 23, 2011, 03:17:20 PM »
  Never used one but with wrench mounted on bicycle spoke it seems that using hook on thumbscrew end over a spoke and the spoke nut in the vise  end you could very handily use wrench to tighten a spoke. Looks like a useful little wrench
Offline Wrenchmensch
« Reply #9 on: June 04, 2011, 04:25:35 PM »
I have a number of spoke wrenches like yours*. They are from the early days of bicycling, when bicycles were a new invention, ca 1880 -1900. Tuning the spokes to where they are resonating at the same pitch became a mania. Demonstrating tuned wheels was a big deal, apparently because they made a lot of spoke wrenches.
*Wald
*Rollfast Perfect
*Dudly
*Stevens
Offline Donny B.
« Reply #10 on: June 04, 2011, 07:15:33 PM »
Wayne
With a spoke in place.
Offline Donny B.
« Reply #11 on: June 04, 2011, 08:12:50 PM »
Another view.
« Reply #12 on: June 04, 2011, 10:03:06 PM »
That is it exactly, Donny!
lzenglish
  • Guest
« Reply #13 on: June 05, 2011, 08:14:50 AM »
Wayne
Thanks for the Demo "Donny B".! A picture is worth a Thousand Words!
Wayne
