Author Topic: 10 1/2 Stanley Cutter forward type  (Read 2648 times)
Offline Jimmy Joiner
« on: August 16, 2019, 01:46:34 AM »
Quote
I had some time in an antique store today, I found a plane with no 10 1/2 behind the frog, only it didn’t have a casing forward of the cutter and chip breaker. No knob section casing whatsoever.
I can’t seem to find easy literature on this model. Has anyone heard of a 10 1/2 like it?
Jimmy
« Last Edit: August 16, 2019, 02:38:14 AM by Jimmy Joiner »
Re: 10 1/2 Stanley Cutter forward type
« Reply #1 on: August 16, 2019, 07:41:25 AM »
Not sure what you have , but a picture may help.
Offline Jim C.
« Reply #2 on: August 16, 2019, 07:45:48 AM »
Jimmy,
Check out this thread:
http://www.papawswrench.com/vboard/index.php?topic=9443.0
For info on the #10 1/2 and #10 1/2C go to page 45, reply 662, pape 63, replies 941 and 942, and page 64, replies 956, 957, 958.
It sounds like the plane you saw was modified.  My guess is that the arches cracked and the plane was “fixed” to create a high angle chisel plane.
« Last Edit: August 16, 2019, 07:48:44 AM by Jim C. »
« Reply #3 on: August 16, 2019, 08:41:28 AM »
Likely a broken tool, cleaned up for re-use as something else.  That plane is notorious for the weakness of the arched area with its opening to allow the cutting iron to stick out on each side.
« Reply #4 on: August 16, 2019, 03:22:56 PM »
Thank you gents, those were my thoughts, just it was such a factory look, whom ever did it has done a skilled job of it. I’ll try and get a picture.
Looks like he has a #72 plane next to it also.
Jimmy
