Author Topic: Using your old blacksmith tools to fix other old tools  (Read 4573 times)
« on: June 01, 2019, 08:22:56 AM »
Well the wife brought home this fence tool from a auction about a year ago. I had it in a post vice soaking the stuck part in atf / acetone which has worked well before. Well time to use some heat. Fired up the coal forge, a little paper, twigs and coal and made a small fire. Only needed a small fire cause only one part of the tool was rusted tight. 15 minutes from starting the fire to pouring water to put it out and it is working now!Made a little more smoke than normal cause the atf burning off.
Re: Using your old blacksmith tools to fix other old tools
« Reply #1 on: June 01, 2019, 09:04:54 AM »
A pic from a different angle
« Reply #2 on: June 01, 2019, 06:12:18 PM »
Hello, Oldgoaly!! Nice rescue, looks great!! Regrds,Lou
« Reply #3 on: June 02, 2019, 08:53:12 AM »
Good work OG! Now you can finally get to work building that fence. :wink:
« Reply #4 on: June 02, 2019, 09:53:17 AM »
I don't think I'm that coordinated to work that tool!
