Author Topic: Huge opening wrenches, least i think they're wrenches??  (Read 2517 times)
Offline wrenchguy
    • Wrenchguys videos
« on: September 08, 2018, 08:17:30 PM »
All 3 look forged, maybe some kind of hammer blow open ends.  Biggest 1 weighs 40 lbs. Opening size and thickness noted on cardboard. Thats a 1' scale for size comparison.
 Anyone seen anything like these?
Online Yadda
Re: Huge opening wrenches, least i think they're wrenches??
« Reply #1 on: September 08, 2018, 10:47:20 PM »
That is some really unique boat anchors.
« Reply #2 on: September 09, 2018, 08:14:25 AM »
Be careful about hanging those on the wall. :grin:
« Reply #3 on: September 09, 2018, 10:55:29 AM »
Wow!!! Those are impressive!! First thing that comes to mind would be for a ship, or, shipyard????? Regards, Lou
« Reply #4 on: September 09, 2018, 12:32:03 PM »
Large steam engine or railroad "slug" wrenches ? But those aren't usually open end.
Offline leg17
« Reply #5 on: September 09, 2018, 03:28:15 PM »
Do slug wrenches have that taper to the shank?
Would the hammer tend to deflect?
I'm thinking that the hole is related to some form of attachment.
Offline wrenchguy
    • Wrenchguys videos
« Reply #6 on: September 09, 2018, 04:10:51 PM »
my thoughts too, some kind bigass cheater bar made to fit the taper, then pinned.  2 wrenches have flat edges, while other has radius edge along taper.
« Reply #7 on: September 09, 2018, 04:53:55 PM »
Railroad??
« Reply #8 on: September 09, 2018, 05:31:42 PM »
Boy, you could do some serious nut-rounding-off with those!
« Reply #9 on: September 09, 2018, 07:20:12 PM »
Motor mount wrenches for a Russian Soyuz rocket. I saw Howard Wolowitz holding on to one during launching.
« Reply #10 on: September 10, 2018, 08:36:10 PM »
Think of large stationary engines like power plants, pipeline compressors, etc.  Box end won't work on a stuffing nut for a valve or rotating shaft.  Hole was for pin for a chain & clevis attached to some external power source (maybe a large lever or block & tackle -- the space where the wrench itself had to work might have been somewhat constricted).
Offline wrenchguy
    • Wrenchguys videos
« Reply #11 on: September 10, 2018, 10:47:01 PM »
yep, my thinking too. big cheater bar would be angled/offset to bring the pull back to horizontal or vertical, not on a 45* axis.   Socket of the bar could be tapered and wrench would be pinned into it.  Tapered fittings wouldn't bind together if pinned slightly loose.  Hole diameter not big enough for clevis/pin torque that might be applied.
